Old 03-24-2005, 01:15 PM   #1
Steve's Avatar
Better gas mileage.
So I was thinking last night, you know how some modern trucks and cars will shut half of their cylinders when they don't need the power. I don't think this would be a tough thing to implement yourself on diesel engine. Possible uses for a switch that would let you disable a few cylinders would be using even less fuel and quieter operation at idle (if you are using your bus engine as a generator or water heater), or traveling on long flat interstates.
Old 03-24-2005, 01:20 PM   #2
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
You'd still be shooting fuel to the cylinders though, wouldn't you, or could you also disable the injectors? (I don't know diesels, but am trying to learn should I go that route in the future.)
Griff is offline   Reply With Quote
Old 03-24-2005, 03:15 PM   #3
Steve's Avatar
No, and that is why it would work easily on a diesel. On a diesel engine you do not control the spark via spark plugs you control the fuel via injectors. These could be easily turned on and off at will. The only problem is that it would still be compressing the air in the unused cylinders, if there were an easy way to change the cam timing on the exhaust valves of those cylinders (which I think is how they do it on the new cars) then you would only loose power due the friction of the cylinder moving. The amount of power lost to compressing the air might not be high enough that it wouldn't be worthwhile trying anyways at least at idle, which is where diesels are more efficient than gas because they are not using as high amount of air/fuel.
Old 03-31-2005, 02:42 PM   #4
skoolie_grease's Avatar
ram implosion wing for better mileage
there's a 'wing' that you can put on your bus that sometimes triples the mileage. no joke. read the reports of users putting these things on their cards, vans, etc.
no one has reported about mileage increase on a bus, but it will certainly help.
here are some links:
http://freeenergynews.com/Directory/Ram ... Wing/data/
http://quantumgravitics.tripod.com/
http://quantumgravitics.tripod.com/id3.html
if you get one up, let us know!
sKOOLie: 1992 International 7.3L Diesel Short Bus
...:: http://www.skoolie.info ..::.. http://www.goodgrease.com ::...
skoolie_grease is offline   Reply With Quote
High Mileage Gearhead94 Mechanical and Drivetrains 14 10-20-2012 01:51 PM
Bad fuel mileage somewhereinusa Everything Else | General Skoolie Discussions 2 03-12-2012 02:42 PM
Fuel Mileage, what do you get thechandler Mechanical and Drivetrains 2 03-25-2010 12:09 AM
WVO vs Diesel Mileage Question ... Hex Veggie Oil | WVO | Biodiesel | SVO 10 03-11-2009 09:51 PM
Short Bus Mileage WilcoxHotel Short-Bus Conversion Projects 5 05-23-2008 07:23 AM
