Old 05-20-2006, 01:27 PM   #21
KevinCoughlin's Avatar
Year: 1983
Chassis: International S1800
Engine: SV396 V-8, International
Send a message via Yahoo to KevinCoughlin
If you are worried about lack of governage on a gas engine - you can change your ignition system. The MSD ignitions for off-roaders have rev limiters - basically it is so that you won't get into a piece of mud or ice and spin the motor up into the danger ranges on accident.
My international has a little electronic box the size of a cigarette package that keeps me from going over about 3600 rpm. I'll probably remove it once I change the ignition (since I'll have the ignition doing it for me).
A few hundred bucks, and you can have it solved - PLUS get more oomph from your bus!
Check out the Millenium Phoenix
<www>
KevinCoughlin is offline   Reply With Quote
Old 05-20-2006, 09:35 PM   #22
msd ignitions
I wasn't aware you could still get the old point conversion ignition systems.
That sounds very interesting. Probably won't happen this summer, but I was thinking I could always use the first governor I've ever seen till I can afford it. a block of wood on the floorboard!
I did buy a tach this spring to put in it, and will be using it heavily as the "Governor" till I achieve a better method.
I even thought about simply limiting the throttle travel ability, but I'm not sure I want to do that.
cogyfarm is offline   Reply With Quote
Rear axle gear ratio. To change or not to change. slade Conversion General Discussions 15 04-24-2017 02:33 PM
Eaton 19050S gear ratio?? Henukaw GM | Chevrolet Drivetrain 8 02-23-2015 01:50 PM
rear end gear ratio change Atridox GM | Chevrolet Drivetrain 2 08-13-2012 09:24 AM
Figuring out which differential gear ratio is right for you Jive Turkey Conversion Tutorials and How-to's 4 06-17-2011 04:23 PM
Changing the Gear Ratio Mat7103 Conversion General Discussions 6 03-05-2004 07:10 AM
