Old 06-17-2015, 09:24 PM   #11
following.... my bus is way to stiff in the back
Turfmobile Build Thread
Old 06-17-2015, 10:04 PM   #12
A note to all of us:
Shocks control rebound. That is all they do. They do not soften the ride. If the ride is harsh, have appropriate new springs made. Don't waste your time and money trying to fix your harsh ride with shocks. If you buy "load leveler" shocks,it just means your original suspension isn't up to what you need--so fix it right. Sure your skoolie rides rough. It was meant to be full of 54, 150 pound third graders and now it isn't. Just say'n. Jack
Old 06-17-2015, 10:10 PM   #13
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Old 06-18-2015, 01:09 AM   #14
Engine: 190hp 5.9 Cummins
Originally Posted by opus View Post
I would bring it to a real spring shop, instead of guessing what the outcome of removing leafs would be. Tell them what you want and have them build you some springs...new. Problem solved correctly.
I agree.
But be prepared to pay $500 to $800 per side.
And since most of our buses run only 50% to 75% full, we remove leafs or replace the spring with New, more modern spring packs containing fewer, but thicker leafs.
This is not some back yard shop I work at. Edmonton truck and spring are the ones that advise and build our new spring packs for us.
Old 06-18-2015, 06:13 AM   #15
150 pound third grader yikes!
Old 06-18-2015, 11:01 AM   #16
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
My bus rides really nice, even when it had seats with no kids. I think RE buses inherently ride better because of all of the weight behind the rear axle.
At the bus rally last week end I had a chance to get individual wheel weights after the conversion. The results are a little puzzling. I wish I would have had the wheel weights pre conversion as it is I only got axle weights. This bus has two 50 gal fuel tanks one on each side with an equalizer pipe.
Here is a diagram of the weights.
I am well under the weights both per axle and total. What puzzles me is the difference from side to side. My fresh water tank is mounted between the frame, in front of the belly boxes, that explains the transfer of weight to the front axle. The gray tanks are alike and mounted on each side at the rear of the belly box, they were empty. The black tank is on the left under the left gray, it too was empty. I have a fairly heavy 4 drawer tool box on the right. On the right is the fridge (not more than 200#) and computers and printers (again not more than 200#) My house battery bank is on the right (four 12V) The rest is pretty much even from side to side. The only conclusion I can come to is that it wasn't even from the factory.
Old 06-18-2015, 11:54 AM   #17
i am curious how many leaves you all have in your leaf springs.
the bookmobile rides rough....this is worth looking into for me
from the manufacturer the plate says:
gvwr - 25,600#
front axle 12,000# (8 leaves)
rear axle 19,000# (9 leaves + helper leaf)
i weighed pre-construction for my plates and the empty truck was 18,000#
no weights since but im guessing 3-4k for the conversion
how many leaves do you have?
Old 06-18-2015, 01:37 PM   #18
Chassis: AARE
I'm afraid none of the figures I have will do you any good. Too many variables
GVWR 36,200
front GAWR 13,200
rear GAWR 23,000
I think, although not positive that your bookmobile is built on the TC2000 chassis which is lighter weight chassis than the All American. I know that Bluebird built their own rear engine buses, again I'm not sure about the front engine TC2000
There are also so many variables in leaf spring design,arch,leaf thickness,leaf length, length of each individual leaf.
cowlitzcoach has probably driven more different buses than all of the rest of us put together, I am convinced that the rear engine buses ride better mainly because of the rear engine.
All of that because it's been raining for a week and it's too wet under there to get my lazy a** under it and count the leaves, but I really don't think it would do you any good.
Old 06-18-2015, 03:28 PM   #19
after reading this thread, i emailed a spring company for a quote. told them my weights, and that i want to soften the ride. here is the email response from spring company:
To "soften" a vehicle of that size is almost impossible with out damaging the integrity of the springs. This is not something we can do here. Anytime you "Soften" a ride usually we would take a spring out of the pack, however due to the size of your bus doing this could seriously damage the vehicle. We therefore unfortunately cannot help you with the springs on your bus.
http://www.denverspringandsuspension.com/index.htm
Old 06-18-2015, 03:39 PM   #20
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Thank you!
