Old 09-02-2016, 06:06 PM   #1
Bi fold air door replacement (single fold air door?)
I'm looking at replacing the bi fold air door on my bus, but I would like to keep the air actuator/piston assembly intact and just relocate it further towards the door and reverse the lines so the original "close" position is now open and vice versa. Are there any decent replacement doors out there or would I best off just fabbing it up. And where can I get a good solid rv lock/handle assembly? Tips and links appreciated.
ntrain6942 is offline   Reply With Quote
Old 09-02-2016, 07:28 PM   #2
Can you post a picture of your door? Or give us a clue what it's on...
I flipped my leading edge (hinge side) piano hinge, braced across the center fold, and added a door lock that's operated on both sides. Only thing that could make me happier is a key fob activated deadbolt cylinder! Chirp chirp
http://www.skoolie.net/forums/f27/lo...ors-14494.html
Are you full timing it?
If so, how do you plan to open it daily? Mine was a pain because it would not exhaust the air fast enough when I pushed the door open or closed... Negating the air cylinder.
Old 09-02-2016, 07:50 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
That's pretty easy, RC or Bluetooth from phone or both.
Old 09-02-2016, 07:51 PM   #4
I conqeur late
Old 09-02-2016, 08:04 PM   #5
Pic of door/bus.
Yes, Ill be full timing it 4 seasons, on a piece of property I just bought in the mtns. So cold winters.
Basically looking at pulling door fully, moving the air cylinder closer towards the door, reversiong the air cylinder action and using a regular swing out door. Even if I have to fabricate it. I want it to be well insulated, so if I fabbed it, there would be a rubber moulding trim going around the frame of the door to seal out drafts.
Old 09-02-2016, 08:11 PM   #6
Dont wanr airtigt
Old 09-02-2016, 08:25 PM   #7
Dont wanr airtigt
Why not?
Old 09-02-2016, 08:41 PM   #8
Houses breathe
Old 09-02-2016, 08:41 PM   #9
Condindsation
Evaprtation
Old 09-02-2016, 09:33 PM   #10
Condindsation
Evaprtation
I was going to be running a wood stove.........dry heat.
