Old 04-01-2009, 10:31 AM   #11
Re: Big Rig Rear End...
hadnt even started it,, it hapeened while i was scraping the lower gasket, i picked up the pushrod a touch to scrape around it and the suction of oil on the end pulled out the peice which fell down into the head abit and was unretrievable thru the small hole. so its called a solid lifter huh, i dont know much about these things.
adamanderr is offline   Reply With Quote
Old 04-01-2009, 03:25 PM   #12
lifter, tappet, cam follower, it may be hydraulic , but it's probably solid and will need to have the valve clearance adjusted mechanicaly when it's reassembled.
Those of you with rear decks... busdriver_phil Conversion General Discussions 5 04-30-2010 09:32 AM
Rear Deck on Bus... aceinthehole2220 Skoolie Conversion Projects 7 07-30-2008 10:49 PM
Looking for a new rear end phillbus914 Classifieds | Buy, Sell, Swap 3 04-20-2008 11:28 AM
just got new rear end 5.57? adamanderr Conversion General Discussions 3 04-07-2008 10:52 AM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 11:52 AM
