Old 09-29-2015, 11:43 AM   #41
Chassis: Blue Bird
Engine: ISC 8.3
Per the Fluid Compatibility Guide at Marco Rubber, NBR (aka Nitrile Buna-N) has "excellent" compatibility with sewage. Looking at the cross-section diagram on that valve's page, though, it's clear that the maximum size object it'll pass is much less than the 1-1/2" pipe it attaches to. Success might depend on how small the toilet grinds things.
Since you picked an electric valve it's obvious you want automation or remote control. What about a traditional bladex valve with a linear actuator? Maybe some Actobotics gizmos to build a rack and pinion, or a wheel with a lever attached (thinking along the lines of the drive mechanism on a steam locomotive)...
Old 09-29-2015, 11:53 AM   #42
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I'm hoping that with a macerating toilet the particles will be small enough, I'm think an electric valve because my tank will be on the right side of the bus so I'm going to have a control panel on the drivers side. Full plan is & I know some people will think I'm silly but plan is pump out black tank, then pump grey tank into black tank to help clean out black tank & waste lines then pump a few gallons of clear water from fresh water tank into pump to final rinse pump & lines, yes there will be another shut off valve in fresh water line with spring loaded check valve before and after shutoff valve.
Old 09-29-2015, 12:15 PM   #43
Chassis: Blue Bird
Engine: ISC 8.3
That's pretty thorough! I wonder whether one pump could be eliminated by mounting the gray tank higher than the black, so that the gray-to-black transfer could be done by gravity.
What kind of hose do you plan to use for the final output? I have a Flojet 18550000A pump for mine. It has a barbed hose output. I used 1" flat discharge hose and found that it doesn't work very well. Where the hose has to bend it constricts a bit, and with the pressure of the pump upstream the constriction quickly becomes a hard kink and it's fiddly to keep the flow going. I'd like to stay with flat hose though because it stores so compactly.
Old 09-29-2015, 12:35 PM   #44
Gravity won't work, far as final discharge my plan is to use ridged 1in from pump to a hose reel then use collapsible 1in hose off the reel, have a lever valve on the very end of that and keep some pressure in it while I roll it back on then open the valve to release pressure that way I wouldn't have to unroll the full length every time.
Need thru tank fittings!! for black water tanks ddpartybus Conversion General Discussions 5 04-18-2015 02:56 PM
Black/Gray Tank Vent kamoo Plumbing, Water and Waste 9 06-24-2009 09:29 PM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 08:53 PM
Gray and black vent pipes oldog12 Plumbing, Water and Waste 17 10-14-2006 12:08 AM
Black/Gray Tanks - need both? vonslatt Conversion General Discussions 5 04-03-2005 09:16 PM
