Old 09-21-2014, 07:04 PM   #1
Year: 1994
Black Tank question
So I have my tank and my location all picked out and am having trouble figuring out what fitting I need on the tank itself to attach the dump hose? I basically just need to know what gets installed into the tank to dump it. Thanks in advance
Matt
SitkaConvert is offline   Reply With Quote
Old 09-21-2014, 10:16 PM   #2
Re: Black Tank question
my tank has a 3inch spigot, then I have a 3inch rubber frenco, then a pc of abs pipe that goes to the drain.
http://www.icondirect.com/holding-tank- ... ch-spigot/
this is a picture of my old holding tank that cracked, that's why I used a rubber fernco on the new set up, this way the rubber will flex
this is the new tank[URL=http://s1172.photobucket.com/user/gbstewart/media/IMG_08301_zpsa85c7c35.jpg.html][/URL
Old 09-22-2014, 05:10 AM   #3
Year: 1994
GBstewert, Thanks for that information, its exactly what I was looking for. In your bottom picture, the new install, is the contraption with the handle, what keeps the drain closed or is that something you hook up when draining? Sorry for my ignorance, I am just trying to work through all the new info. Thanks
Matt
Old 09-22-2014, 07:01 AM   #4
there called a gate valve,, there's a bunch of different set ups you can get from a rv place, you can have one for grey water and black water, so you drain your black tank frist then grey tank that way your hose is flushed out
http://www.valterra.com/product-categor ... ducts/oem/
Old 09-23-2014, 03:51 PM   #5
Year: 1994
Thanks for all your help, I think with these products I will be well on the way to getting a tank installed.
Matt
Black tank question??? dirtygoat Plumbing, Water and Waste 5 10-27-2011 12:59 PM
Black tank dump valve syke Conversion General Discussions 7 09-12-2011 04:55 PM
One Tank or Two? (Grey/Black) Hex Plumbing, Water and Waste 13 06-29-2011 06:30 PM
Fuel tank for black water bluebird90 Conversion General Discussions 13 04-14-2011 07:21 PM
black water tank and a door sportyrick Classifieds | Buy, Sell, Swap 16 04-19-2008 11:39 PM
