Old 05-21-2012, 12:57 PM   #1
Re: bleed the coolant system
you can just fill the radiator tank with water, run it for a bit, and refill it a couple of times... thats what i did. also check antifreeze temp when you are done...
Old 05-21-2012, 02:03 PM   #2
did you just block off each line at the "t"? thats what i did.. on modern cars, there is a bleeder valve - often in the thermostat housing because of the crossflow radiator and adding coolent only can be done to the coolent tank. maybe you have one.
Old 05-21-2012, 04:45 PM   #3
opus's Avatar
Chassis: All-American R/E
Thats interesting. What you could do too is park with the engine up hill of the rest of the bus. The more drastic the hill, the better. Refill your coolant and all the air will head up hill.
Old 05-22-2012, 03:05 PM   #4
just dont do like i did after i removed the second heater and found only one plug - instead of the 2 required. forgot about it... started bus, then wondered why there was water dripping out on the backside of the rear wheel arch.
for some reason it took quite a bit of water after i discovered the problem.
however, i did find out, that the radiator was only 1/3 empty, which tells me that the heater hose system being higher than the engine means that water is still in the engine block and that its water pump must be circulating water. thats my observation.
Oil in the coolant? dieselman69 Conversion General Discussions 36 07-10-2020 03:01 PM
Bleed the fuel lines or prime the pump? She won't start! the_experience03 Mechanical and Drivetrains 15 01-22-2017 08:02 PM
1991 DTA360 Coolant System Flush Procedure shoeshiner International | Navistar Drivetrain 14 11-01-2015 01:08 AM
Water bleed port in the air line? TygerCub Conversion General Discussions 3 03-06-2012 09:24 AM
Cat 3208 coolant drain? paul iossi Caterpillar Drivetrain 2 11-11-2009 12:32 AM
