Old 03-17-2015, 07:07 PM   #1
Engine: DT466 w/MT643
Rated Cap: 71
Blower Motors?
Hey All,
We were wanting to keep the two front heaters by the door and by the driver seat. They are the stock heaters. The btu rating on them is insane. 60k and 80 btu's if I'm not mistaken. I'm not sure if there are different types of heaters that came stock on these beauties, but they're radiators essentially and air is either pulled or pushed through the fins to heat the air. The one by the door is tip top.We decided to keep the heaters of course after the one by the driver seat spent the last year or so outside unprotected. Needless to say the fan motors are not in the best running condition. I hooked them to 12v and nothing.
The driver side heater has a puller fan to draw air over the heating unit and blow it out the vents and there was a blower fan with a 4" hole for the defroster.
My questions are: where can I find a new replacement for these two? and anyone have any idea how much air these things moved? I'd hate to replace them and not have the same awesome output they had before we set them outside.
We're in the Sacramento area. Any advice would be much appreciated.
Heath, Laura and The Kids
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
heathnlaura is offline   Reply With Quote
Old 03-17-2015, 07:08 PM   #2
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Where about in the Sac area??
Old 03-17-2015, 07:13 PM   #3
Rated Cap: 71
Elk Grove actually. I'd be willing to drive to replace 'em though. I remember driving back from Reno in it and it started to snow up over the pass. I turn the valve on the driver side heater and turned the fan on and WOW. You can really tell they over did the heaters to compensate for lack of insulation in these things.
Old 03-17-2015, 07:18 PM   #4
I was just wondering I'm over in Vacaville
Old 03-17-2015, 08:08 PM   #5
Engine: 190hp 5.9 Cummins
Any 12 volt blower motor out of any car or truck will fit if your handy with tin snips, and know how to connect a few wires.
The original motors were kind of loud. Something like a ford f150 blower may be much less noise.
I would start at the pick and pull myself.
Old 03-17-2015, 09:09 PM   #6
lornaschinske's Avatar
Rated Cap: 89
Do you want new blowers?
Try here. You might want to get their catalog. They even have the round diffuser assemblies used on my Blue Bird. Prices don't seem too bad to me.
Oh, and you can also get some body parts.
Fulltime since 2006
Old 03-23-2015, 05:55 PM   #7
Rated Cap: 71
Thanks a lot guys....and gal. I found a place called a-z bus sales and they have a warehouse not too far from me.
I was looking at blower motors for other cars and either they had a mounting plate in a that would cause the motor not to fit with the fan on it or they were just too expensive ($50 at FLAPS).
Thanks again.
Old 03-23-2015, 06:02 PM   #8
$50 for a new blower is cheap. Do you want used?
Old 03-23-2015, 07:47 PM   #9
I just pulled 5 of the flat ones and 2 squirrel cage motors out of mine yesterday, I'll send u the best one(s) if u pay for shipping. I was going to scrap them, but the prices are SOOO low it's not even worth the fuel.... I know the one for the drivers front slides in, but all the motors should be the same with the exception of the squirrel cages.
I just noticed we basically have the same skoolie!
Destroymix is offline   Reply With Quote
Old 03-24-2015, 07:51 AM   #10
That's the skoolie spirit. ;)
Old 03-24-2015, 09:47 AM   #11
I just lead by example, cuz this forum rocks!
Old 03-24-2015, 05:57 PM   #12
Rated Cap: 71
Destroymix....that sounds awesome. I have no idea how to send a private message, but I'm going to learn right now.
Gotta love this type of community.
Old 03-24-2015, 06:44 PM   #13
just go to someone's screen name, and choices will appear. ;)
