Old 03-25-2007, 01:43 AM   #1
abdabbs's Avatar
Chassis: Ford B700
Engine: orig.327, now 429
Send a message via ICQ to abdabbs Send a message via AIM to abdabbs
blower motors
I was wondering if anyone here has had the pleasure of replacing a blower motor in a BlueBird. My front drivers side is sounding something awful !! Today I removed all dash metal from left to right and before I went any further I thought I would probe for some insight.
Can you remove the blower by just removing the lower side panel or do you think I will have to tear the whole left area apart ( all around the wiring YUCK !!)
If it would help I post some pics let me know.
Thanks in advance for all your input.
abdabbs is offline   Reply With Quote
Old 03-25-2007, 11:21 AM   #2
Engine: 7.3 diesel
I'd say a picture may help since there is a few different set ups.
And is it a defroster blower or is it the drivers blower by the feet.
If it is like my 92 international convetional the blower down by the feet looks like it can be removed by taking off the panel and you will see the motor there which you should be able to match one up at a auto parts store.
I had just tore mine apart so I can run bolts down through the floor for my fresh water tank. I have my heater core off to the side still and everything under it is exposed. I'll go and tak a picture.
Old 03-25-2007, 11:43 AM   #3
Engine: 7.3 diesel
The defroster blower looks as if it might be a bit more work to get at.
Old 03-25-2007, 09:35 PM   #4
abdabbs's Avatar
Chassis: Ford B700
defroster blower
The blower that is giving me the problem is the defroster blower. Which looks to be the harder one for sure. Ill take pics of my progress but I need it done as it is essential to be able to see when going down the road with 20 plus bodies putting out humidity !
Old 03-25-2007, 11:42 PM   #5
Yo is that a veggie system in that pic, I'm building a system very similar right now if that is what it is.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Old 03-26-2007, 12:00 PM   #6
sportyrick's Avatar
Chassis: F33695
blower motors
If they aren't howling too bad I drill a tiny hole in the back bubble where the bearing is and put a few drops of oil in there and then put a few more where the front bearing is by the fan blade. works pretty good. On my flat nosed BB I pulled the right panel that the headlights are mounted in and had access to the blower motors. sportyrick
Use for central HVAC heating coils or blower motor? stonestatue Everything Else | General Skoolie Discussions 2 09-23-2012 01:07 AM
My New Monster Snow Blower Project... lapeer20m Everything Else | General Skoolie Discussions 6 01-21-2012 10:39 AM
Need blower motor for roof RV AC frank-id Classifieds | Buy, Sell, Swap 3 07-31-2009 11:47 AM
blower motor needed abdabbs Classifieds | Buy, Sell, Swap 3 03-25-2007 10:30 PM
cat motors rayne Everything Else | General Skoolie Discussions 8 03-27-2006 12:35 PM
