Old 08-20-2007, 11:51 PM   #1
Re: Blue Bird Ignition Interlock
what turns the key or the engine turns over? If the key is in the column and it won't turn try tuurning the steering wheel, their is a pin that locks the wheel from turning that can sometimes mechanicaly bind the key/linkage to the unlocked position. if the key is in the column the electrical ignition switch should be on top of the column under the dash and is operated by a linkage rod from the key/lock assembly. if this isn't helpful,try to be more specific with what the symptoms are.
Suzie Blue - Our 1990 Blue Bird TC2000 mtunderwood Skoolie Conversion Projects 23 07-01-2015 05:48 AM
2000 Blue Bird Mini Bird CLEAN! buswizard Classifieds | Buy, Sell, Swap 3 06-12-2011 06:11 AM
New to the Blue Bird dragonfly112 Conversion General Discussions 2 12-14-2009 06:08 PM
1985 Blue Bird 'Micro Bird' Griff Short-Bus Conversion Projects 34 07-21-2009 01:35 AM
Blue Bird #1 dentarthurdent School Bus News 1 03-18-2008 09:06 PM
