Old 06-06-2007, 11:37 AM   #1
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: BlueBird All American Gas Tank Switch
Why do you think there is rust in the tank? Just take extra fuel filters and tools with you. I wouldn't go through
the trouble of changing the tank unless I had to.
I'm hungry!
You Gotta Let Me Fly
Old 06-09-2007, 01:19 PM   #2
trx
trx's Avatar
Chassis: Chevy C-60
Engine: 8.2L Turbo Detroit Diesel
Send a message via ICQ to trx
If the tank was sitting with water in then there may be rust in it. If not then I would not worry about it (unless you can see inside and see rust flaking off). There are many vehicles that sit for years before someone brings them back into service and don't have problems with rusty fuel tanks (like my '73 IH Scout II). Bus fuel tanks are not easy to remove & install (been there, done that). Big, heavy and lots of steel around them for crash protection.
Chad
trx is offline   Reply With Quote
Old 06-09-2007, 09:10 PM   #3
oldog12's Avatar
... If it ain't broke, don't fix it...
oldog12 is offline   Reply With Quote
Old 06-19-2007, 11:00 AM   #4
I would consider adding a second fuel filter is a easy to get to place after the tank and before the rest of the system..that way the filters easy to swap if you have to...and sounds easier than a tank swap far from home.
Demonknight is offline   Reply With Quote
Old 10-05-2007, 11:04 AM   #5
crazycal's Avatar
BigTex, I sent you a PM. If you didn't get it, please let me know. Thanks.
I'm hungry!
Old 10-21-2007, 09:46 PM   #6
BBTC2K's Avatar
Year: 1983
Coachwork: GMC
Chassis: RTSII
Engine: 6V92TA
Rated Cap: 55
Send a message via AIM to BBTC2K Send a message via Yahoo to BBTC2K
Yes, I agree. Dont change out the tank. I believe it will be ok. it apparently hasnt sat around all that long, and I have personally started stuff that has sat around for 15 years (what a treat) and i simply added a clear plastic inline gas filter to it, and even though you may change it out occasionally, it is way cheaper and less aggaravating than dropping that tank. The bus is a 86, so you should be fine. And like Demonknight said, mount it where you can get at it easy in case you need to change it roadside.
shawn
School Bus Driver/Instructor/Mechanic...
proud single custodial dad to 18yr old son Jeremey, who wants to try his hand at driving my RTS
BBTC2K is offline   Reply With Quote
Installing a different tank mount and/or fuel tank jazty Conversion General Discussions 16 09-15-2014 06:42 PM
1988 Bluebird All American....your input please jbemom Conversion General Discussions 13 08-27-2014 09:59 AM
headlight switch for a 1989 bluebird Jarlaxle Mechanical and Drivetrains 1 04-01-2011 12:18 PM
1991 BlueBird All American chamilion Skoolie Conversion Projects 7 08-26-2010 11:08 PM
Comparing Bluebird TC2000 and All American dentarthurdent Conversion General Discussions 20 12-22-2007 06:02 PM
