Old 02-06-2016, 05:03 PM   #1
Year: 1994
Chassis: Blue Bird TC2000
Engine: Cummins 5.9 12V
Rated Cap: ??...It's 28' long
Bluebird T2000 Accordion Door Question(s)
First: Thank you SO much to all the wonderfully helpful veteran skoolies here. Your patience and willingness to share your knowledge and expertise is priceless.
My question(s): How in the heck do you get into a 1994 Bluebird T2000 with an accordion door (air opener)? I just pushed it open when I was looking at it but that seems rather crude.
Is it possible to lock said door? Or do I need to plan on replacing it with something else?
Thanks! I don't even know what questions to ask (and the proper terms) so I do appreciate your patience.
Lisa
Here's a pic of the door in question:
lizzabus is offline   Reply With Quote
Old 02-06-2016, 05:06 PM   #2
Year: 1994
Another pic of the door:
Old 02-06-2016, 06:05 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I would suggest either:
a. A lock and hasp on the rear of the door
b. A keyed drop bolt
Old 02-07-2016, 01:56 AM   #4
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
That's generally correct. There should be a manual release above the door to bypass the air line.
Captain Obvious on deviantArt
Old 02-07-2016, 07:59 AM   #5
THis particular lock is made almost entirely of pot metal is sorta famous for breaking.
Old 02-08-2016, 04:11 PM   #6
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Yeah, but something like this. Remember, a lock only keeps honest people honest. A determined thief will find a way in.
Old 02-08-2016, 06:27 PM   #7
Right on.
That pot metal one won't require as much determination though!
Old 02-13-2016, 09:19 AM   #8
I have the same bus and the lock pictured is the one I used... seems to work well. I can turn off the air valve at the top of the door and lock it from the outside. I had to drill the door out to install it.
DRBW is offline   Reply With Quote
Old 02-13-2016, 09:35 AM   #9
Year: 1994
DRBW: Would you please post a picture of your setup? I'd like to see where you put the lock. THANK YOU so much!!
Old 02-13-2016, 02:47 PM   #10
opus's Avatar
Chassis: All-American R/E
Is there not a lock at the bottom of the door?
Old 02-13-2016, 03:26 PM   #11
http://www.skoolie.net/forums/member...albums865.html
There are pictures of the door at this address
Old 02-13-2016, 03:30 PM   #12
Old 02-13-2016, 06:30 PM   #13
Year: 1994
Looks great! But my door hinges in the middle and closes from the front toward the back of the door opening.
Nope. There isn't a lock on it anywhere. Hence my problem.
Old 02-13-2016, 06:31 PM   #14
Year: 1994
No. But I am contemplating how to install one there. Door opens in..."single" hinge door - doesn't open in the middle.
Old 02-13-2016, 06:41 PM   #15
It might also fit on the leading edge of the door against the door frame
Old 02-13-2016, 06:46 PM   #16
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
You'll have to drill some holes in order to install the lock.
Old 02-13-2016, 06:47 PM   #17
opus's Avatar
Old 02-13-2016, 06:49 PM   #18
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Like this:
If this is the case, then what DRBW posted IS one solution. What Opus posted is another solution. But, Opus' solution would involve gymnastics when locking the door from the inside for the night.
Old 02-13-2016, 07:02 PM   #19
opus's Avatar
Thats what your foot is for.
Old 02-14-2016, 11:41 AM   #20
Year: 1994
You guys are great!! Thank you so much. Now I have several options to investigate.
Thank you for taking the time to take/post pictures and offer your suggestions!
