Old 02-06-2016, 05:03 PM   #1
Year: 1994
Chassis: Blue Bird TC2000
Engine: Cummins 5.9 12V
Rated Cap: ??...It's 28' long
Bluebird T2000 Accordion Door Question(s)
First: Thank you SO much to all the wonderfully helpful veteran skoolies here. Your patience and willingness to share your knowledge and expertise is priceless.
My question(s): How in the heck do you get into a 1994 Bluebird T2000 with an accordion door (air opener)? I just pushed it open when I was looking at it but that seems rather crude.
Is it possible to lock said door? Or do I need to plan on replacing it with something else?
Thanks! I don't even know what questions to ask (and the proper terms) so I do appreciate your patience.
Lisa
Here's a pic of the door in question:
lizzabus is offline   Reply With Quote
Old 02-06-2016, 05:06 PM   #2
Year: 1994
Another pic of the door:
Old 02-06-2016, 06:05 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I would suggest either:
a. A lock and hasp on the rear of the door
b. A keyed drop bolt
Old 02-07-2016, 01:56 AM   #4
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
That's generally correct. There should be a manual release above the door to bypass the air line.
Captain Obvious on deviantArt
Old 02-07-2016, 07:59 AM   #5
THis particular lock is made almost entirely of pot metal is sorta famous for breaking.
Old 02-08-2016, 04:11 PM   #6
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Yeah, but something like this. Remember, a lock only keeps honest people honest. A determined thief will find a way in.
Old 02-08-2016, 06:27 PM   #7
Right on.
That pot metal one won't require as much determination though!
Old 02-13-2016, 09:19 AM   #8
I have the same bus and the lock pictured is the one I used... seems to work well. I can turn off the air valve at the top of the door and lock it from the outside. I had to drill the door out to install it.
DRBW is offline   Reply With Quote
Old 02-13-2016, 09:35 AM   #9
Year: 1994
DRBW: Would you please post a picture of your setup? I'd like to see where you put the lock. THANK YOU so much!!
Old 02-13-2016, 02:47 PM   #10
opus's Avatar
Chassis: All-American R/E
Is there not a lock at the bottom of the door?
