03-11-2016, 12:13 PM
Year: 1994
Chassis: Blue Bird TC2000
Engine: Cummins 5.9 12V
Rated Cap: ??...It's 28' long
Body Leading Floor Holes?
Is there a reason I wouldn't want to practice my body leading technique on the numerous holes in the floor before I pretty up the exterior of Serenity? I know there are a LOT of holes but I've got to plug them up somehow.
I've read about lots of different options for plugging the holes before I put down my flooring. Just thought using them for body leading practice might be an option.
Your thoughts?
Thanks!!
Lisa
03-11-2016, 01:55 PM
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
Your thoughts?
Thanks!!
Lisa
Good God, lead body work hasn't been mainstream for at least 50 years. Health hazards. Maybe duraglass or JB weld, or welding with a mig/tig, or even someone on here used caulking.
03-11-2016, 03:32 PM
Rated Cap: 2+1
Ole school, I like it!!! A true lost art.
A master body man could lay it on and be flat and ready to work in notime at all. They could Make the guys just starting with plastic look like they stood back and threw it at the side of the car.
I was trained with lead
So many years ago..don't think I would know where to start now.
Do you have the tools?
Don and Ellen
Plus one fuzzy faced kid (Poopcee)
03-11-2016, 03:33 PM
Roger that. Lead make you dead (or just crazier than before).
03-11-2016, 05:10 PM
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
Leading is my plan. Modern body solder is now available lead free.
03-11-2016, 05:17 PM
Year: 1994
Ha ha ha! I'm pretty crazy now!
Yea...thought the "traditional" lead might be a bad idea (if I could even get it in Washington state). Good to know there's lead-free stuff I can use.
I watched several videos that used a propane torch (got one) and a couple "smoothers" along with the tinning compound. I'll look around and see what I can find.
I think I might just use tin caps on the flooring and wait to spiffy up the various holes on the exterior with the body leading technique.
Thanks for the input, my skoolie sweeties!!
03-11-2016, 05:44 PM
i plan on using brass bar ends that are about 3/4 of an inch and 6 inches long from work for free as a back stop to weld the holes shut. although leading might be easier.
03-12-2016, 09:27 AM
Engine: Cat 3126e
Rated Cap: 28
I used fiberglass on all of the holes. Took almost 2hrs not even. The prep work took longer.
03-12-2016, 09:30 AM
I zapped all of mine with a mig.
(Note to self...remember to treat the underside of the welds with a rust preventative.)
03-12-2016, 12:31 PM
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
I saw a thread on here where one of our members used solder instead of body filler on the outside, can't remember who it was, but it turned out nice. Soldering seems to be ok, just use rosin core!!!!
-Doc
03-12-2016, 01:09 PM
I used Blackjack roof sealer on my first rusty floor. It obviously stops the rust and prevents moisture from touching the metal again. It also plugs all those holes when it's troweled, as if you were preparing for tile, just before putting down your precut sub-floor pieces.
