Old 05-19-2005, 08:03 AM   #1
Chfsfn2's Avatar
Coachwork: Ward
Engine: 5.9L Cummins Diesel
Bolting/attaching seats
Anyone have an easier way to tie down bus seats than drilling through the floor and using bolts/washers/nuts?
We removed the seats from a bus, cut the legs off, attached them to 2x4 frames to give us storage room, and are remounting them sideways to allow a bigger aisle. Planning to drill holes through the floor and bolt, unless we can find an easier way.
Thanks!
See my bus here
Chfsfn2 is offline   Reply With Quote
Old 05-19-2005, 12:39 PM   #2
trx
trx's Avatar
Chassis: Chevy C-60
Engine: 8.2L Turbo Detroit Diesel
Send a message via ICQ to trx
How about just screwing them to the floor? It would be alot less work. At most you would have to pre-drill the holes if you are going through sheet metal. Most everything in my bus is just screwed down.
Chad
trx is offline   Reply With Quote
Old 05-20-2005, 02:38 PM   #3
lapeer20m's Avatar
I love self tapping screws ! I used hundreds of self tappers in the construction of my bus.
They will drill through some pretty thick metal. I have drilled dozens of them through 1/4" steel without any problem.
Old 05-20-2005, 05:25 PM   #4
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
self taping screws
Ditto!!
They have saved gobs of time and numerous drill bits. Good call.
-Richard
captainkf is offline   Reply With Quote
Old 05-20-2005, 09:16 PM   #5
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
I agree that self-tappers would be the bee's knees, but what about down the road after prolonged exposure to the elements. Are you guys putting caulk/sealant around the ends that stick through? I had thought about going the other way with mine, drilling pilot holes, then from under the bus, using neoprene washer head self-tappers and cutting off any ends that are exposed to the interior.
The reason I ask is that those who owned my bus before me went through with dry wall screws & they were rusted severely and many just broke upon removal attempts.
Griff is offline   Reply With Quote
Old 05-23-2005, 11:05 AM   #6
Chfsfn2's Avatar
Coachwork: Ward
Thanks for the replies. I thought about self-tapping, but with the beating the seats & shelving will take on bike rides, we decided to go ahead and bolt through the floor. Worked out pretty well.
See my bus here
Old 05-23-2005, 10:33 PM   #7
I think the bolts are the best way to go. Screws may not be strong enough in an accident. The manfacturers used bolts for a reason.
busone is offline   Reply With Quote
Old 05-24-2005, 12:28 AM   #8
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Lag Bolts
My bus had two attachment points on the foot of each leg. The forward hole had bolt, but the rear hole had about a 5/16" lag screw. At least using that combinationwould save you a little time.
Eric von Kleist is offline   Reply With Quote
Old 07-05-2005, 03:49 PM   #9
bolting down seat
I'd go for the bolts, too. The orginal set-up used bolts. Ever wonder why? These self-tappers are available to all of the bus companies; yet, they still bolt through the floor. They also use washers to keep things from yanking out in an accident. Oh yes, I'd go to "grade 8" bolts too. More expensive, but stronger than the cheapies.
For empty holes coming through the floor, you might consider "seam sealer" which can be purchased from an auto body supply store.
Herb in Utah
Skoolie BOBB is offline   Reply With Quote
Attaching wood to inside of bus? HickoryHusker Skoolie Conversion Projects 13 04-19-2017 02:54 PM
attaching Polyisocyanurate bapos Conversion General Discussions 10 07-16-2013 09:58 AM
Question attaching rack to bus. icnivad Conversion General Discussions 6 02-16-2013 09:48 PM
Attaching 2x2s to wall putterspitt Conversion General Discussions 8 05-06-2010 04:23 PM
attaching to side walls dieselman69 Conversion General Discussions 2 03-12-2009 11:04 AM
