Old 02-29-2016, 10:38 AM   #1
rjnye79's Avatar
Engine: T444e
Boondocking Fridge
Hey there skoolers (is that a thing?)!
Just wondering what everybody thinks about the best type of fridge for boondocking. We will be full timing for a couple of years with some, possibly, lengthy stretches of off-grid days. We do plan on having solar power. Though it may be a smaller system, as we are currently shopping five and six window rigs. We also plan on have a propane tank for hot water and range/oven, perhaps.
In my research, it seems like propane is best for lower energy consumption. However, it has been increasingly brought to my attention that there is a significant(?) fire hazard with these. For that reason, I almost want to abandon propane systems in general. How realistic are these concerns and do any of you have more creative refrigeration solutions?
As always, thank you guys for your time and generosity!
rjnye79 is offline   Reply With Quote
Old 02-29-2016, 10:52 AM   #2
Propane has been used safely in RV's for many decades. That said...there have also been plenty of fires. Like many other systems, safety really comes down to how well designed, installed and maintained it is. I was told by my insurance agent years ago that electrical fires are actually a much more common cause for RV loses.
Personally, I would not include refrigeration in my propane plans though. Those units require near perfect level or they can have the coils go solid and never recover. I have been investigating the new generation of 12 volt fridge/freezers that employ a new type of high efficiency compressor and I'm pretty much sold based on what I have seen & heard in terms of performance. One such brand is Whynter. They are the only one I have found so far that make a combination fridge/freezer in a single unit. Not the cheapest option out there but based on my needs, I think it is my best option. (Note...they are all chest type...no uprights)
Old 02-29-2016, 11:13 AM   #3
dredman's Avatar
I have been running a cheap AC dorm fridge off of 2oo watts solar during the day for the last 6 months(98% of the time I am boondocking) Of course, if you want more power, or you need to cool things down at night, you may need more than one battery and more watts, but shockingly this works for me as long as I turn the fridge off around 3 pm, or crank the generator.
Mine was $120 at Home Depot
Magic Chef 3.5 cu. ft. Mini Refrigerator in Black, ENERGYSTAR-HMBR350BE1 - The Home Depot
I know that many folks might be outraged by my response, but it works.
I just like folks to know there are options besides what is "standard"
My Skoolie Story on YouTube
dredman is offline   Reply With Quote
Old 02-29-2016, 11:30 AM   #4
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
We converted a small chest freezer (33"L x 22"w x 24"H, $30 on craigslist) into a fridge with a cheap $20 thermostat controller from Amazon. It pulls 230 watts but the compressor might run only a couple hours total each day if we leave it turned on. Otherwise we'll set it to freeze and run it for half and hour then turn it off for the day. If the weather is under 50 degrees we do that, if it's hot we'll turn it on for a short time a few times a day. If you do have solar you'll have no problem at all.
My build thread:https://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
onenationundergoat is offline   Reply With Quote
Old 02-29-2016, 12:02 PM   #5
rjnye79's Avatar
Engine: T444e
Thanks, we definitely are of the mindset for minimalizing our energy usage in general. In fact, I think we are going to restrict our propane needs to cooking only. It seems also that chest cooler/freezers are more efficient at staying cold. That is, they don't dump cold air out onto the floor every time you open them? So I think we're gonna go that route...
Old 02-29-2016, 12:04 PM   #6
rjnye79's Avatar
Engine: T444e
That's really good to know, dred. We have been talking about maybe trying to snag a smallish used fridge/chest freezer (with temp controller) and using an inverter to essentially make it two-way, 12/120. Does that sound realistic?
Old 02-29-2016, 12:08 PM   #7
rjnye79's Avatar
Engine: T444e
Yes! I love the chest freezer idea. It seems to be a pretty efficient set up, spacially (put it on rails under a counter top?) and consumption-wise. We will certainly use that advice about limited usage hours too. Thanks!
Old 02-29-2016, 12:13 PM   #8
rjnye79's Avatar
Engine: T444e
Also, as water heaters go, saw this one recently... Bosch Tronic 3000T ES4 Electric Mini-Tank Water Heater, 4 Gallon - boschtanklesswaterheaterproducts.com - BuyAndLarge Inc
...anyone know about their performance? We only need hot water for dishes and showers, for the most part. Also, sorry that I just bombarded the hell outta this thread! :/
Old 02-29-2016, 12:51 PM   #9
Robin97396's Avatar
I also like the idea of a chest freezer because it doesn't block the windows and it provides another work surface. On a side note home beer brewers have been using freezers, with an additional thermostat, to cool their homebrew for years. You can find those thermostats easily on brewing websites.
5 gallon kegs make a petty nice water system. You pressurize the keg with co2, so your water may get slightly fizzy if you leave the system pressurized.
Are there any other rolling home breweries out there?
Thinking of your shower situation, I've seen people set up shower curtains in their front entry stairwell because it's designed to shed water.
Are you using a wood stove? Personally I put my brewing kettle (5 gal) on my wood stove. Even with propane using a ceramic heater I can boil 5 gal in under an hour. Most people seem very happy with the on demand water heaters if you want to get fancy. I like to keep things capable of functioning in a simple manner using natural resources if necessary.
Old 02-29-2016, 02:38 PM   #10
Since I've not been able to find a small, tankless water heater that runs on either propane OR electric...I am looking into using one of each with a simple diverter in the water line to pick the appropriate energy source. Propane when boondocking...electric when I have a hook up.
Has anyone else gone or considered this route?
Old 02-29-2016, 04:09 PM   #11
Robin97396's Avatar
Yeah, I've never seen a duel fuel tankless water heater. I bathed out of a steel pot in a tent for so many years that a nice bucket of hot water in a warm bus seems pretty easy. In those days we got one steel pot of warm water. First we'd brush our teeth in it, then bath in it, then wash socks and underwear in it and finally shave all in the same water.
Then if you were tough you'd drink it. Not really.
Old 02-29-2016, 06:03 PM   #12
Chassis: TC2000 RE
Engine: 8.3l Cummins
I have a fridge/freezer that runs on 12 or 24 volt dc, and the compressor consumes about 80 watts when it's running. In order to keep the beer cold and ice frozen, it runs around about 30 percent duty cycle @ 70 degrees F.
This is easily powered by a solar panel, a car battery, and a charge controller. Oh, and it operates at up to 30 degree angles.
aaronsb is offline   Reply With Quote
Old 02-29-2016, 07:28 PM   #13
dredman's Avatar
I think everything sounds realistic except the "used" part. I started out with a used drm fridge and trade for the new one when I discovered it was useless without shore power or generator. The new one is WAYYY more efficient. I like goat's idea, as I spill all my cold air out EVERYTIME I grab a beer, but I could not do the top-open thing. Find something efficient and I bet you will achieve the results.
Old 02-29-2016, 09:41 PM   #14
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
i got the vissani 9.9 C F from H D for 299 bucks. .7 amp running and 1.6 surge. nice unit.i unplug it about 6 pm and plug it in before i leave for work in the morning.
my build pics
Old 03-01-2016, 12:45 AM   #15
Chassis: TC2000 RE
12 volt/120 volt:
EdgeStar 63 Qt. 12V DC Portable Fridge/Freezer - FP630
Old 03-01-2016, 06:10 AM   #16
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Originally Posted by aaronsb View Post
you could almost fit a gallon of milk in there
my build pics
Old 03-01-2016, 10:20 AM   #17
Anyone here is experimenting with ice boxes as alternatives for powered fridges?
mrblah is offline   Reply With Quote
Old 03-01-2016, 10:34 AM   #18
Unless you super-insulate one and use dry ice, they are only good for a couple of days at best with "ordinary" ice. Even then you might only stretch it to four days or so and either way you'd need to stay near an ice supplier.
Her is some of the newest and most efficient tech available these days...
Whynter LLC
Old 03-01-2016, 11:16 AM   #19
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Do you have a link to that controller? The last one I saw was about $70.
I'm hungry!
You Gotta Let Me Fly
Old 03-04-2016, 10:03 PM   #20
Chassis: Thomas
Rated Cap: 60
Well as far as the ice box idea goes... when we don't wish to use power for our chest freezer/fridge conversion, we put a five gallon bucket in it with a 10 lb bag of ice inside. The ice doesn't even begin to melt for a couple days and keeps the fridge cold for at least four days. And this thing is very poorly insulated.
