Old 06-10-2010, 01:36 PM   #1
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
Re: Boondocking Ideals/Newbie
With the right filter (and pump) you can fill your potable water tank from many good sources such as mountain lakes or streams. 0.2 micron filtration will screen every microbe except viruses. Be careful about areas with agriculture, livestock, or near cities though. More urban surface water may have disolved heavy metals, which require activated carbon to filter out. Viruses can be inactivated with eight drops of clorine bleach per gallon. In a pinch you can use a backpacker filter. For your on board tanks you'll want a filter with larger flow rate, however.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: http://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 06-10-2010, 03:17 PM   #2
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
pictures! also your junkyard friend should be able to hook you up with another rear end right?
Old 06-10-2010, 04:04 PM   #3
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Your buddy should be able to hook you up with a rear end from a single axle semi. Those are super cheap and plentiful. You might want to check to see if the wheels take regular semi tires (11X22.5). The more you can standardize the cheaper everything will be for you. Also scavange for an RV air conditioner. You may not need it all the time, but when you need it you really will need it. Sounds like with a little patience, tenacity, and luck you should have an outstanding skoolie. Don't forget, insulation is your best friend....
M1031 is offline   Reply With Quote
Old 06-10-2010, 10:32 PM   #4
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
Very valid points Smitty.
Old 06-11-2010, 09:02 AM   #5
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
An 8 window bus is a great balance between size and maneuverability. I have an 8 window bus and I can drive that thing pretty much anywhere and it has plenty of room for 2 people inside comfortably. They are usually referred to as a mid-size bus, or a 3/4 size bus. Though my brother keeps calling it a 'short-bus'...I am sure just to get under my skin. Like Smitty said, make sure you check it out really well and that you can get the title for it, otherwise you may be in for a lot of headaches.
Now THIS is a SHORT BUS.....
Old 06-11-2010, 07:46 PM   #6
JakeC's Avatar
Hahahaha...wow, where in the heck is that?! That is hilarious!! I bet it gets good mileage, lol...
Brutus
Newbie Saying Hi ThisIsNotMyUserName New Member Intros - Say Hello! 2 09-24-2013 05:19 PM
Boondocking in S Dakota for Prairie Dog shooting? ErrabundusBus On the Road | Travel, Trips, Camp Sites, Tailgates 6 08-14-2011 07:41 PM
Boondocking Locations lornaschinske On the Road | Travel, Trips, Camp Sites, Tailgates 0 12-13-2010 04:20 PM
Newbie PeterBird Skoolie Conversion Projects 4 02-24-2008 01:05 PM
newbie buslover55 Conversion General Discussions 2 08-06-2007 04:44 AM
