Brake master cylinder location????
I have a 1999 Bluebird bus that has the brake fluid reservoir located directly behind the drivers seat. I would like to relocate it. Is there any reason I couldn't move it to under the bus in a water tight enclosure.Does the reservoir have to be mounted at a level above the master cylinder? Thanks
