Re: brake pedal "sticking" w/air brakes?
My brake pedal does the same thing, ultimately I'd suggest replacing the pedal. In the meantime do what I do, squirt the hinges with WD-40, CRC or something similar and work the pedal up & down a bit and that should fix it up for now!
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
