Old 04-12-2010, 09:28 AM   #1
breaker box
I wanted to get you guys opinions to see if the breaker box amp needs to exceed your alternator output amp. We have friends with an rv that have a 50 amp circut breaker box. that would seem to me to make it untrue that the breaker box amp needs to be greater than the alternator output amp.
I have a delco remy 22si alternator in our 1990 bluebird schoolbus but all the numbers are missing. Would anyone know the amp output on these alternators?
chaos is offline   Reply With Quote
Old 04-13-2010, 12:08 AM   #2
Re: breaker box
Thanks for the response guys. Perhaps I'm misunderstanding this. I've been reading a book called "Rv Electrical Systems" and on page 62 is has a small section entitled "Circuit Breakers" and is saids " A cuircut breaker of suitable amperage should be installed between the isolator and each battery bank. Suitable amperage is the next size above the alternator output: for example a 150 ampere circuit breaker for a 135 ampere alternator" Are they taking a bout a fuse perhaps or ??????
Breaker Box Installation Questions soused moose Conversion General Discussions 17 09-05-2017 09:49 AM
LED dome lights and Circuit Breaker crisnpropa Alternative Fuels | Electric, Propane, Wood & Biofuels 8 10-04-2016 11:44 AM
30 amp breaker panel ?s jpatt Conversion General Discussions 4 07-12-2004 08:20 AM
