Old 05-12-2012, 07:11 PM   #1
Broken outer rear door handle
Ok, so apparently I've gotten superhuman strength somewhere along the way... that or the door handle has decayed over the winter. (I prefer the former explanation) Earlier this week, when I went to open the back door, the handle came off in my hand.
One edge of it, which looks like it had most of whatever epoxy was holding it in place, is still firmly attached to the door; and it still latches just fine, as long as you do it from the inside.
Can anyone suggest a fix, we don't have any bus graveyards nearby so getting a replacement would not be easy.
So far my only idea is to try to chip off the leftover (not sure how easy that would be). Get a short pipe of some kind, drill out a hole about the size of the edges, then cut a line for the points of the square, bend them back a bit, then hammer it on to force the square hole. Not sure how to fasten from there.
Is there some easier method to replace it I'm missing, or a glue/epoxy that might hold the original in place?
Dain is offline   Reply With Quote
Old 05-12-2012, 10:01 PM   #2
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Re: Broken outer rear door handle
Maybe drill a hole in the shaft, and a matching one through the back of the handle... then tap it for threads and bolt it on?
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 05-13-2012, 07:28 PM   #3
TygerCub's Avatar
Engine: Detroit
Garage door handles have square shanks. Maybe you can use one of those?
Old 05-13-2012, 09:13 PM   #4
My super human buddy did the same thing to the rear door handle on my old bus (pot metal just ain't what it used to be). I found a "T" shaped handle with a 1/4 " square shaft on epay for $9 delivered. The shaft was too long biut it did not take much to fix that. Good luck
Old 05-14-2012, 09:26 AM   #5
i have one with a square shank that i removed if ya want that. and i think i even know where it is...since i took it off yesterday...
Old 05-15-2012, 04:07 PM   #6
Seeria's Avatar
Thanks, guys. We'll check homedepot and see what we find. Failing that, might take you up on that offer chev49. We're off outside Klamath Falls OR at the moment, where the chipmunks know how to work door handles -- good thing ours fell off.
Old 05-16-2012, 09:26 AM   #7
bonanza chipmunks no doubt
Rear Door hoser Skoolie Conversion Projects 13 12-23-2017 11:28 PM
Do you use the rear door of your bus? stonestatue Conversion General Discussions 12 10-01-2012 11:50 PM
Side door/ Rear door SeanF Conversion General Discussions 6 05-24-2009 11:56 AM
Rear door BusDude Classifieds | Buy, Sell, Swap 0 11-01-2006 02:40 PM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 11:52 AM
