Old 06-14-2018, 12:23 PM   #1
RevyRev's Avatar
Coachwork: Ward Senator
Budgeting Conversion
Greetings,
I am planning to purchase a bus in the next 60 days. Can someone tell me the tools I will need to purchase to demo, tools to prep floors, lay down plywood subflooring, electrical, plumbing, and basic carpentry. I am putting together my budget.
Thank you,
RR
RevyRev is offline   Reply With Quote
Old 06-14-2018, 12:54 PM   #2
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Originally Posted by RevyRev View Post
Greetings,
Thank you,
RR
An angle grinder with cutoff wheels is your best friend in the demo phase.
I've got a miter saw, jig saw, and circular saw. A table saw would be handy, but you can get by with these. I use my cordless drill and impact driver a lot as well, don't necessarily need both. a large pry bar (like 18" give or take) helped a lot getting out the old floor and where I needed leverage.
A generator to power yours tools as well if you don't have a power hookup already. Generator was needed for me since im in a storage lot without power.
https://www.skoolie.net/forums/f11/n...tml#post256987
My build thread - Started 3.2.18
jjhwick119 is offline   Reply With Quote
Old 06-14-2018, 02:05 PM   #3
RevyRev's Avatar
Thank you jjhwick! Starting my list.
Old 06-14-2018, 02:24 PM   #4
Air compressor. Air chisel. angle grinder. Drill and bits. Fan.
Old 06-14-2018, 03:57 PM   #5
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
For all.of the phases I've gone through so far, in no particular order
Big Pry bar if your floor is glued down well
Angle grinder. Has been the number 1 tool I've used so far.
A broom and dust pan or shop vac. Or both
A decent socket set
Circular saw
Impact driver
Drill
Wire crimp
Caulking gun
Clamps
Wrenches
Big scrub brush
A few really good pairs of gloves. I'm on fourth pair.
A decent straight edge
Measuring tape or 4
Masks
Hammer/mallet
Big ole scrapper
Gorilla tape for when you remove stuff off body or windows and it's gonna rain before you replace/repair area
Heavy duty trash bags
Heavy duty chisel
Razor knife and extra blades
Nick
Old 06-14-2018, 04:15 PM   #6
RevyRev's Avatar
Just saw your list and noticed you live in Brevard. I live in Melbourne! Did you purchase your bus in Florida? Are you the bus converter who lives on Merritt Island?
Thank you for such a comprehensive list! So much to add to my ever growing spreadsheet.
Thank you,
RR
Old 06-14-2018, 04:17 PM   #7
RevyRev's Avatar
Forgot to add drill bits. Thank you!
Old 06-14-2018, 04:23 PM   #8
Ninjakitty's Avatar
Hey hey!
Thank you,
RR
I picked mine is from publicsurplus.com
She is a lil rusty, but I'm.from Florida, I can make it work
She was in Coral Springs
Your like 20~ minutes away, come.on over
Nick
Old 06-14-2018, 04:56 PM   #9
RevyRev's Avatar
Florida Strong!
Originally Posted by Ninjakitty View Post
Hey hey!I picked mine is from publicsurplus.com
Y'all Floridians are mighty and strong! It must be the sun, the heat and hurricane survival. I have seen your work on IG. You got it.
I spend a lot of time sitting on the Indian River at the park below the causeway. I know many people who live on Merritt Island. And, all the good restaurants are over there.
I will message you on IG when I get back.
Old 06-14-2018, 04:57 PM   #10
I used to live over in Vero and would bring a jay, a sandwich, and a fishing pole and spend the day over on the side of the Indian River fishing around the mangroves.
Old 06-14-2018, 05:05 PM   #11
RevyRev's Avatar
That sounds like a perfect day in Florida!
Old 06-14-2018, 05:53 PM   #12
RevyRev's Avatar
A decent socket set
Circular saw
Impact driver
Drill
Wire crimp
Caulking gun
Clamps
Wrenches
Big scrub brush
Measuring tape or 4
Masks
Hammer/mallet
Big ole scrapper
Heavy duty chisel
Is a straight edge a ruler?
Old 06-14-2018, 06:50 PM   #13
Ninjakitty's Avatar
Yeah, it can be. I have a 6 foot harbor freight level I use. I also have a couple types of carpenter squares. It's just to draw straight lines.
Nick
Old 06-24-2018, 12:41 AM   #14
xrw44's Avatar
Engine: T444e v8 turbo
Rated Cap: was 72, now 3
Exclamation A lot of tools!
what he said plus:
welder, bench grinder
pliers, vice grips,
socket & open-end wrenches in 1/2 and 3/8 etc.
solder gun plus heat shrink tubing
wire cutter/stripper + tape
several philips head screw driver bits, quality lasts longer.
18v drill + 2 batteries
area light and strong flashlight
camera to picture what you cant see
air compressor and a brad nailer for trim
1"D and 2"D [and others] hole saws [go in a drill]
jig saw for cutting odd shapes
12" and 24" carpenters square
carbide circular saw blade
reciprocating saw with wood blade and metal blade
table saw for ripping plywood and spruce
plastic pipe scissors
and
dozen silicone caulk
dozen latex acrylic caulk
dozen liquid nails
screws! 1", 1.5", 3", and self-taping
metal-wood primer
wiring nuts
2 dozen corner braces for shelves and cabinets
lots of drinking water and
No build thread but pictures and text are at
https://www.skoolie.net/forums/members/16889-albums.html
xrw44 is offline   Reply With Quote
Old 06-26-2018, 06:41 PM   #15
Engine: 466e
Rated Cap: its Yuge
I am about 1/3 of the way through and have found it to take way more Miller Light than originally anticipated
+1 for impact driver, grinder, saw
MambaJack is offline   Reply With Quote
Old 06-26-2018, 09:24 PM   #16
RevyRev's Avatar
Drinking Water and Popcorn!!
Originally Posted by xrw44 View Post
what he said plus:
pliers, vice grips,
and
dozen liquid nails
metal-wood primer
wiring nuts
Yes! Popcorn surely is good for the nerves!
Old 06-26-2018, 09:25 PM   #17
RevyRev's Avatar
Looks like I will be adding beer AND wine to my list of tools! Thanks. Haha!
Old 06-26-2018, 10:35 PM   #18
...and a little Tequila for those special moments.
Old 06-28-2018, 10:02 AM   #19
RevyRev's Avatar
Amen! Awomen! I will start stocking up now!
Old 06-28-2018, 03:03 PM   #20
I was recently handed a bottle of EXPENSIVE bourbon to try. Its called Pappy van Winkle Family Recipe or something like that. It was AMAZING!!
Sorry if OT!!
