09-11-2018, 05:52 PM
Year : 2002
Coachwork : Bluebird
Chassis : All American RE (A3RE)
Engine : Cummins ISC (8.3)
Rated Cap : 72
Buffing wheel for HF polisher?
Hello Everyone,
I purchased the Harbor Freight 7" polisher to use on my Alcoa's with the idea that I would put a sewn buffing wheel on it.
I have the darn polisher and cannot find a buffing wheel to fit it.
I may be looking at the right one and just don't recognize is. The shaft is 5/8"x11.
I have found plenty that go on a bench grinder but none with the proper pieces to fit the polisher.
Any suggestions would be appreciated.
Thanks.
S.
09-11-2018, 06:23 PM
Year : 1999
Coachwork : Genesis
Chassis : International
Engine : DT466/3060
Rated Cap : 77
How is the hand polisher mount different than the bench grinder?
09-11-2018, 06:55 PM
Year : 2002
Rated Cap : 72
Originally Posted by
o1marc
5/8" x 11 threaded shaft like an angle grinder.
I need a wheel with a threaded arbor to match. Or an arbor that will fit the wheels that I see and thread onto my polisher.
09-12-2018, 11:17 AM
Year : 2002
Rated Cap : 72
my Google-Foo is failing me
09-12-2018, 12:01 PM
Year : 1999
Coachwork : Genesis
Engine : DT466/3060
Rated Cap : 77
I assume the polisher came with a spin on pad base? Can you not use the wheel you want and put the 5/8" nut from the bench grinder on the polisher. Post a pic of your arbor.
10-26-2018, 12:59 PM
Year : 2002
Rated Cap : 72
Ok.....
Back to trying to get my polisher equipped to polish the Alcoa's on my truck.
Pics of polisher and the kind of wheel/pad that I am trying to attach:
10-31-2018, 04:45 PM
Year : 2002
Rated Cap : 72
Any thoughts?
10-31-2018, 05:03 PM
Year : 1997
Chassis : GMC
Engine : Cat 3116
Rated Cap : 72
Are you sure that is a polisher? Sure looks like a mini grinder from the pic?
10-31-2018, 05:04 PM
Year : 2002
Rated Cap : 72
This 7 in. electronic polisher gives you all the power and control you need for a wide variety of applications. The strong 10 amp motor generates between 1000-3500 RPM for optimum polishing.
https://www.harborfreight.com/7-in-1...her-62297.html
10-31-2018, 05:07 PM
Year : 2002
Rated Cap : 72
BlackJohn
If you can read upside down, the label in the pic says "polisher".....
10-31-2018, 05:10 PM
Year : 1997
Chassis : GMC
Engine : Cat 3116
Rated Cap : 72
Well I learned something else new today. Very similar looking tools. That would be handy.
Don't the threads match up? Maybe the tool is left hand threaded?
That's all I got for you.
10-31-2018, 05:12 PM
Year : 2002
Rated Cap : 72
BlackJohn
The sewn wheels that I have found, so far, have not been threaded.
10-31-2018, 05:17 PM
Year : 1997
Chassis : GMC
Engine : Cat 3116
Rated Cap : 72
PNW_Steve
And do you need that black back plate to use or will the sewn wheel just push onto the shaft?
10-31-2018, 06:22 PM
Year : 2002
Rated Cap : 72
I may have found something...
https://zephyrpro40.com/product/supe...polishing-kit/
Now to confirm that this is the right stuff for my Alcoa's and if it will fit my HF polisher????
Who knew that polishing four wheel would turn into such a process......
10-31-2018, 06:42 PM
Year : 1999
Chassis : TC RE
Engine : 8.3L
Pure old school polish for use with high speed machine. Pre DuraBrite.
GaryC
10-31-2018, 07:59 PM
Year : 2002
Rated Cap : 72
Gustav
Is that a specific product recommendation?
High Speed? I am pretty sure my polisher maxes out at 3000rpm.
Not really sure what you are saying.....
» Recent Threads
