Old 07-01-2013, 07:53 AM   #1
jkronmiller's Avatar
Chassis: IH
Engine: 444E
Building propane tank under bus storage
Yet another question - this time about mounting propane tanks. I have been reading (trolling ) this forum for about a year and I remember seeing one conversion where they showed up close how they made a box to hold two 20lb tanks underneath that was easy to remove the tanks for filling. I have just spent the last week trying to find that conversion so I could refresh myself and start building one for my bus. Does anyone know which conversion that might be or if you have a design yourself that you would be willing to share that would be great! Thanks!
jkronmiller is offline   Reply With Quote
Old 07-02-2013, 07:40 PM   #2
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Re: Building propane tank under bus storage
Your design should be straight forward. I think a lot depends on what material your going to use. I plan on using angle iron and probably weld in some expanded sheet metal in the bottom. The reason for this is you need to have it open on the bottom. Propane is 1.5 times denser than air so it likes to settle to the bottom. If its open it has a way to escape so it cant collect and wont go boom.
Again how you mount it to the bus may influence your material you use, good luck let other know how you did yours.... pics pics pics.
Old 07-02-2013, 08:49 PM   #3
mine is a box steel frame out of angle iron, then wood sides and bottom, 2 20lb propane fit behind each other, plus room for other stuff, I have to go to check my thread and see what pics of it I think I just show the start , and if not to many ill post some more.
Old 07-02-2013, 09:43 PM   #4
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by jkronmiller
... I remember seeing one conversion where they ... (fill in the blank). I have just spent the last week trying to find that conversion...
Originally Posted by bapos
...let other know how you did yours.... pics pics pics.
I think we need to start doing more documentation on how we do things. Double posting somethings may help... like LP Lockers, Dinette tables, etc. While you might have it in a build thread, putting it in a thread dedicated to a specific subject and contributed to by other would make it so much easier for those who go looking for info.
Fulltime since 2006
Old 07-02-2013, 09:48 PM   #5
wmkbailey's Avatar
Engine: 3126
Lorna,
Like your AC post.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 07-03-2013, 11:13 AM   #6
Rated Cap: 89
Yes, like that. It allows anyone to look at several versions of doing the same thing. Much easier to figure what way would work best since there is more than one way to do most anything.
Fulltime since 2006
Old 07-04-2013, 09:25 AM   #7
bapos's Avatar
Not sure what it would take to get a major section put up but maybe a "how to build" section
Building Storage Bins Ron Conversion General Discussions 21 09-23-2015 05:45 PM
building basement storage Ryan Grimm Conversion Tutorials and How-to's 5 09-07-2013 08:49 AM
Building my own wvo tank ZombieCrow Veggie Oil | WVO | Biodiesel | SVO 12 07-08-2010 12:48 PM
Building/buying basement or underside storage compartments? dentedvw Conversion General Discussions 1 02-06-2010 01:59 PM
propane tank storage? captainkf Conversion Tutorials and How-to's 5 01-20-2006 07:38 PM
