Old 09-15-2015, 08:19 PM   #21
ErrabundusBus's Avatar
Engine: International DTA 360
[QUOTE=Ryan Grimm;3252]
I'd worry about the strength of any wood box mounted on the exterior of my rig-to-be, you can only do so much with wood sheet goods in a structural design, especially a HANGING design. Joint design and construction would be critical, even with a good fibreglassing. I'd also worry about delamination of the glass with exposure to humidity.
Weld up a frame of angle iron and box it in with 3/4 treated plywood.
Matthew and the Errabundus Crew
"Make it so Number One"
https://errabundusbus.blogspot.com/
ErrabundusBus is offline   Reply With Quote
Old 09-23-2015, 04:45 PM   #22
sojourner's Avatar
Engine: DT408
Check out my build thread for some ideas on basement storage. Not finished yet but you can easily see where I'm going with it. In the Skoolie conversion forum, my build is titled "Sojourner".
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
building basement storage Ryan Grimm Conversion Tutorials and How-to's 5 09-07-2013 07:49 AM
Building propane tank under bus storage jkronmiller Conversion General Discussions 6 07-04-2013 08:25 AM
Building/buying basement or underside storage compartments? dentedvw Conversion General Discussions 1 02-06-2010 12:59 PM
Building Luna KC10Chief Skoolie Conversion Projects 5 12-22-2007 01:27 PM
holding tanks and storage bins shaggy Plumbing, Water and Waste 6 03-28-2006 09:33 AM
