Old 03-12-2004, 07:33 AM   #1
Bus front door question
I pulled our buses origional front door off yesterday...and am in the process of building a real door for it .
I'm trying to figure out what that little door lock/close pressure switch does on the articulated arm closure handle.
Is it just an alarm switch to notify the driver that the door isnt secure.
Or does it do more ...
I'd like to pull it off and get rid of it , but I'm not sure what the 4 wires leading to the switch do.
Any ideas would be a help.
Our bus is a GMC 1991
Thanks folks
Are you questioning my Aaa-thoritttyy ?
soused moose is offline   Reply With Quote
Old 03-12-2004, 09:46 AM   #2
Les Lampman's Avatar
Hi Michael,
Are you talking about the switch that's by the open/close handle (it closes against it)? It's what turns the flashing lights on when the driver picks up the kids. You've probably got a 'master' switch on your electrical panel to turn the whole system on and off. On my bus there's a manual button to get the Amber Flashing Lights going before the bus stops and then the Red Flashing Lights come on automatically when I open the door and shut off when I close the door (the Amber Lights go off then too; until I mash the button again).
Oh yeah, it also makes the side 'STOP' arm go out when the door opens.
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Old 03-12-2004, 06:48 PM   #3
Thanks Les......
Old 04-22-2004, 08:32 PM   #4
andybus9's Avatar
It also turn the light on in the stair well if you have the headlights on too
andy B Bus#9
Minnesota
andybus9 is offline   Reply With Quote
Replacing the front door Zephod_beeblebrox2 Conversion General Discussions 13 09-14-2022 11:19 AM
the front door latch Zephod_beeblebrox2 Conversion General Discussions 5 11-22-2014 11:02 AM
Deadbolt on front door? lornaschinske Conversion General Discussions 31 08-25-2014 10:35 PM
NEED front door hinges millertyme Classifieds | Buy, Sell, Swap 1 09-20-2009 11:43 AM
Front door size busone Skoolie Conversion Projects 4 01-24-2006 12:40 AM
