Old 06-26-2012, 12:49 AM   #1
Bus interior question ?
I've watched a few videos and looked a few more photos of conversions.
My question is this; What type of insulation is between the inner galvanized and the outer skin ?
The reason I ask is if you are going to live full time, wouldn't it be better to add some substantial
home type insulation ? ( Icynene foam insulation )
Also this would give you a chance to check for rust and wiring issues.
I know this would be a massive undertaking drilling rivets, marking panels, and so forth.
Maybe I'm too worried about it lasting a long time.
1967_Turner is offline   Reply With Quote
Old 06-27-2012, 08:33 AM   #2
roach711's Avatar
Rated Cap: 19
Re: Bus interior question ?
Usually it's fiberglass batts. If you have any window or roof leaks it may be wet fiberglass batts.
The foam insulation does give more R value per inch, with the spray-in stuff best of all. It's also the most expensive but for a full-timer it may be well worth the price.
The Roach Motel
Interior wall removal question? sickrunvanyardsale Conversion General Discussions 4 06-03-2014 01:15 PM
Little Intro & Question re: RE interior solution scgwagner Conversion General Discussions 5 03-31-2014 09:38 AM
Bus interior dimensions? SweetBearCub Conversion General Discussions 5 09-04-2013 05:59 PM
Framing the interior Firearm Conversion Tutorials and How-to's 15 04-17-2011 08:07 PM
What is the interior height of your bus? nearhomeless Conversion General Discussions 6 05-28-2009 09:00 PM
