Old 01-29-2011, 08:37 PM   #1
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Bus Kote
To those of you who have used Bus Kote, what kind of coverage did you get? I'm planning on using Bus Kote and Clear flex.
Thanks.
Old 01-29-2011, 09:28 PM   #2
houskou's Avatar
Coachwork: flatnosed
Chassis: amtran/bluebird/thomas
Engine: diesel
Re: Bus Kote
did you try a search?
here is one guy that used it
viewtopic.php?f=9&t=6181#p58305
The sun is the same, in a relative way, but you're older; shorter of breath, and one day closer to death.
Pink Floyd - Dark Side of the Moon
houskou is offline   Reply With Quote
Old 01-30-2011, 04:06 PM   #3
Chassis: AARE
Re: Bus Kote
GlenC
I read your post three times before I found that 4 gallon thing. Your roof sure looks different than mine. Mine is a complete hump without the center lowered channel. You used 1/2 gal primer and 4 gallons of Bus Kote. How much clear did it take? Did you consider just buying the ceramic balls and mixing it to your own paint to save shipping costs? To get it shipped to me from FL is $100. I have a rack that takes up almost a third of the roof area. That area has what I can only describe as corrugated metal with the ridges having flat tops. It is unpainted, but not rusty, so it must have some kind of coating. I probably won't use it a lot, but I will use it. Do you think I could coat the entire area, or maybe just the valleys to any advantage?
Thanks,
Dick
Old 01-31-2011, 06:24 PM   #4
Chassis: AARE
Re: Bus Kote
Glen
Those were kind of my thoughts, just nice to hear it from someone else. I don't have much hope of talking mumsywumsy into full time, but maybe a couple of months in the winter headed south.
I do however sit out in a field in the sun in the summer, with just the windows open.
Old 07-02-2012, 09:43 PM   #5
edfrank's Avatar
Coachwork: Wayne Lifeguard
Chassis: Navistar International
Engine: 7.3 Power Stroker Diesel
Rated Cap: 24
Re: Bus Kote
Hello,
I have been trying to place an order with www.hytechceramics.com/ for Bus Kote, the Bond-it, and FlexiClear, but the website will not take orders. Does anyone know if they are still in business or are simply having problems? I will call them tomorrow again by phone.
Ed
edfrank is offline   Reply With Quote
WOW! NASA Technologie meets School Bus Roofs - Bus Kote usmcbay Conversion General Discussions 21 10-05-2016 10:19 AM
