Old 11-04-2004, 04:24 PM   #1
rabiznick's Avatar
Send a message via AIM to rabiznick
Bus Leveling
Just curious as to how you folks level your buses when setting up at a campsite. Are mechanical (elec/hydraulic) systems worth the trouble?
Real new to all this stuff, would appreciate your input...Russ
rabiznick is offline   Reply With Quote
Old 11-05-2004, 10:04 AM   #2
Steve's Avatar
I don't bother leveling I really don't notice it. I imagine some simple blocks of wood would work just fine.
Old 11-05-2004, 04:05 PM   #3
rabiznick's Avatar
Thanks Steve..I was wondering just how critical it is to level up when parked. I hear others talking about how level the rig must be for the sake of the fridge. Or is that just another "boondockers legend"?
Old 11-06-2004, 11:47 AM   #4
Rick78EFI460's Avatar
I find it more comfortable to sleep if I level the bus somewhat, but I don't spend too much time worrying about it , I just carry some blocks to put under the low wheels and drive onto them. I have some camping trailer stick on levels stuck inside the bus, one in the center of the dash, and one on my left side panel beside me. I can drive up the boards I carry and watch the levels. Too easy, quick, and cheap.
Rick Russell
Rick78EFI460 is offline   Reply With Quote
Old 11-06-2004, 11:47 PM   #5
lapeer20m's Avatar
Having the bus somewhat level is reasonably important for the jacuzzi. I"ve considered fabricating some elaborate hydrolic leveling system like the expensive motorhomes use, but I've found that a few 2x4's work just fine. I keep a few in the back of the bus. They're about 2 feet long each. I've used up to two or three boards thick before. IF the boards are used on the passenger side, it can make for a big first step!
It's really easy to stack em up and pull the bus up on top. Most times i only level the rear tires, but doing the fronts would also help i suppose.
Some hardwood planks would work better in teh long run. I've destroyed my share of 2x4's from the extreme weight of the bus. Also, it's a good idea to have the wood under both tires on the same axle. If you're loaded heavy and only put boards under one of the duals the tire really buldges qutie a bit. This is probably not so good for the tire, and makes the leveling process that much more difficult since the buldge can easily negate the height of at least one 2x4
just my 2 cents, hope this helps.
Old 11-07-2004, 06:47 AM   #6
Rabiznick …Leveling a rig is really important if you use an RV absorption-type of LP Gas fridge.
(Those are what 99% of RV’s & Buses use )
Those fridges don’t work well if they’re not pretty level. And eventually you’ll ruin them if you try to run them that way.
If you go for a regular electric Fridge, run off your inverter …then you don’t have to worry about it being level.
I’m going for a really good quality & energy efficient fridge in the trailer I’m going to build. We’ll be able to run it off 120 AC (line in) or off our inverter when necessary.
Michael
The Mobile Homestead
http://www.mobilehomestead.com
Are you questioning my Aaa-thoritttyy ?
soused moose is offline   Reply With Quote
Old 11-07-2004, 01:26 PM   #7
Coachwork: Ward Genesis
Engine: DT466/MT643
I drive onto 2x10 planks, & will probably level with trailer-style crank-down jacks to keep the bus from moving on the suspension.
The LP reefers are much improved--it takes quite an angle to hurt them, though they are more efficient when perfectly level.
Jarlaxle
Old 11-07-2004, 02:34 PM   #8
If your bus has air bag suspension you can make an automatic leveling system like the transit buses have.
busone is offline   Reply With Quote
Old 11-08-2004, 05:24 AM   #9
rabiznick's Avatar
Thank you all...that's what I love about this forum , Russ
Leveling Jacks houskou Conversion General Discussions 2 08-05-2010 12:25 PM
Leveling your bus... ezbme Conversion General Discussions 9 10-25-2009 02:26 PM
Does anyone have a leveling system ? Kirbystud Conversion General Discussions 3 08-27-2009 08:54 PM
Skoolie leveling KC10Chief Everything Else | General Skoolie Discussions 4 09-30-2007 12:17 AM
leveling jacks? The Wanderer Conversion General Discussions 33 03-14-2007 01:52 AM
