Old 01-13-2010, 09:13 PM   #1
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Bus seat foam
I looked around a bit and found some pictures and posts regarding those of you that reused your bus seat foam. I would actually like to reuse mine for a couple bench seats and the dinette seats I plan on making.
My plan is to build the benches over the front wheel humps (same as "G BUS") which would make the total width about 24". The bus seat foam is only about 18" wide.
I was wondering if any of you custom cut and glue your foam together to get the desired size. If so, after you cover the foam can you notice creases all over the cushions where they are glued together?
What about comfort? Can you notice a difference sitting on them?
I would prefer to get a one piece section that is the right width and length and have it be one solid piece. But the stuff is pretty expensive and I have seats from 3 buses sitting in my yard (first bus I sold after I took seats out, second bus I kept, 3rd bus is my buddie's). So needless to say I have PLENTY of foam.
So what are your recommondations for constructing the desired size?
Dan
BUSBOZO is offline   Reply With Quote
Old 01-13-2010, 11:36 PM   #2
Chassis: C60
Engine: Chevy 7.4l 454 FI
Rated Cap: 59
Re: Bus seat foam
you can get rid of the creases by gluing on a thin layer, 1/4" or so on top the whole thing before covering. I made a queen size mattress from mine, took 8 cushions then covered with a single piece of 1 1/2" foam I had been using under my sleeping bag.
ramairws601 is offline   Reply With Quote
Old 01-13-2010, 11:46 PM   #3
lornaschinske's Avatar
Rated Cap: 89
Re: Bus seat foam
You can glue foam together using either contact cement or the contact cement that comes in aerosol spray cans. You can find them in the craft section of Wal-Mart or in stores like Hobby Lobby or Michael's.
http://www.michaels.com/art/online/disp ... Num=gc0212 (I've used this one on foam)
http://www.michaels.com/art/online/disp ... Num=gc0265
Fulltime since 2006
Old 01-14-2010, 09:22 AM   #4
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Re: Bus seat foam
My bus seats were mostly covered with carpet padding. It's not too expensive, new at the hardware store. I used carpet padding for the "upholstered" part of my driver's area. I covered 3/8" plywood panels with layers of carpet padding and put old seat material on top for the upholstery.
Eric von Kleist is offline   Reply With Quote
Old 01-14-2010, 08:20 PM   #5
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Re: Bus seat foam
Ah ha! Gluing a layer on top. I like that idea. I was just outside digging up the seat bottoms from a mountain of seat frames, plywood and rubber flooring. Of course I didn't plan on using the original seat foam so its been outside exposed to rain, freezing temps and squashed and buried. LOL
Old 01-15-2010, 07:29 PM   #6
Seeria's Avatar
Re: Bus seat foam
*bangs her own head* Why the heck did I not think of this! Here I've been searching for used or new foam ... DOH
Old 01-17-2010, 09:44 PM   #7
sportyrick's Avatar
Chassis: F33695
Re: Bus seat foam
busbozo: If you go to my gallery pictures and look at my couches you may get some ideas. I built angle iron frames for the bottom and seat backs and put 3" foam on plywood with fabric stretched over it to make comfortable seats. We also put seatbelts behind them for the kiddies. I built sheet metal boxes to stash bedding in and to support the couches and attached the lower frames to them. We lift the lower cushions out of their frames to get access to the bedding and the uppers fold down between them to make a king size bed with bars supporting the backs.The arms are the only thing that hold the seat backs on and have a lean built into to them to make them comfortable. We put a memory foam mattress topper on to soften the 38# per sq. in. foam which is what I would recommend for a comfortable ride while motoring down the road. We have taken many trips with these seats and wouldn't change a thing and have spent many nights on the bed and it's huge and very comfortable with additional padding added to it. It is a little work to put up and take down but is the best way to get both jobs done equally well. sportyrick
Old 01-17-2010, 10:11 PM   #8
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Re: Bus seat foam
Thanks Rick. I'll check it out!
Spray Foam Question White99z Conversion General Discussions 18 11-03-2016 10:26 AM
Expanding foam insulation PDBreske Conversion Tutorials and How-to's 10 02-25-2014 08:31 PM
Looking for plush seat cuchion foam putterspitt Conversion General Discussions 2 02-02-2011 03:04 PM
spray foam under floor - who has done it? ramairws601 Conversion General Discussions 6 10-16-2009 05:29 PM
Using seat foam for insulation?? Lady Franklin Conversion General Discussions 2 12-10-2008 01:06 PM
