Old 10-08-2017, 12:12 PM   #1
Engine: dt466e
Bus seats
Where in Houston area can i rid of my bus seats? I called a few junk hauling places but they weren't cheap so i figured I'd do it myself. How'd you guys go about it?
adic27 is offline   Reply With Quote
Old 10-08-2017, 12:52 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Put 'em up on craigslist- somebody will want them. Free!!!
Old 10-08-2017, 04:22 PM   #3
I have pulled the seats out of two buses this year. I tried to give the seats away on CL.
Lots of flakes..... After 15-20 no-shows I hauled them to the scrap yard. They helped me unload them and didn't charge me.
Old 10-08-2017, 04:41 PM   #4
Engine: dt466e
Thats what i was thinking to do. Thanks!
Old 10-08-2017, 06:07 PM   #5
CCurran88's Avatar
Chassis: 2003 International CE; 2 A/C Units; PS; Air Brakes
Engine: T444E 7.3L Diesel Engine
Rated Cap: 72 Passengers
seats
we took them apart - the foam seats and board backs went to the dump - $4.50. Then we took the 800 lbs of steel to the recycle yard, + $50. Put the leg of one of the seats through the lights on the trailer , -$25. Enough left over for dinner at Jimmy Johns for 2.
Redheadraptor
CCurran88 is offline   Reply With Quote
Old 10-08-2017, 06:28 PM   #6
Traveling
Rated Cap: '00
Wow. Maybe weld all them seat frames into some cool yard art.
This how to solder copper tubing. I'm not sure what it has to do with your seats, but I found it educational.
Old 10-08-2017, 10:23 PM   #7
Engine: dt466e
funny
Old 10-09-2017, 12:00 PM   #8
golfersmurf57's Avatar
I have 16 left to pull on mine. You might get online and offer on a church site. Most school systems have plenty on their deadlines. I'm taking these to the dump.
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
Old 10-16-2017, 01:10 PM   #9
Engine: dt466e
Did 800 lbs of steel come from the seats alone? Or is that with the inside walls? How much per pound did they pay?
Old 10-16-2017, 01:18 PM   #10
Traveling
Rated Cap: '00
How much per TON. One poster on the Board said his reward for al that work was a couple Jimmy John sandwiches.
Old 10-16-2017, 01:31 PM   #11
Engine: dt466e
For the legs i can get 4 cents a pound. Dont know if thats good or not. Called a few landfill places and one said they charge a flat rate of 50+ bucks for the foam part. Jimmy john mentioned -$4.50. Any suggestions? Im in pearland Texas by the way.
Old 10-16-2017, 02:02 PM   #12
CCurran88's Avatar
steel alone. I did have some interest from a couple of hunters to put a seat or two in their deer stands, but none got back to me as to how they wanted them delivered and I needed to get them off of the trailer. They were cool with that.
Redheadraptor
Old 10-16-2017, 02:03 PM   #13
CCurran88's Avatar
Pearland is 3 1/2 hours away from Lipsitz recycling, where I took my steel. Probably not worth the drive to get the $50 or so.
Redheadraptor
Old 10-16-2017, 02:11 PM   #14
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
WOW!! Fantastic video resource Rusty - THANK YOU!!!
Back to the seats. If you are interested in some change, hauling them to a recycling yard is the answer - probably after removing all the non-metal (may depend on the yard). In my case, I wanted them gone ASAP so I could get busy. I advertised on Craigslist and thru in a $50 bill. Someone was there the same day to haul them (and the cash) away.
JD - Full timer out west
My Adventures & Build
Old 10-16-2017, 02:31 PM   #15
I took mine to the local recycle yard and they took them for free and helped me unload.
That was the best I could manage.
Old 10-16-2017, 03:59 PM   #16
the seats I did remove from my carpenter bs, I just set them out by my street the night before trash day.. and the guy in an old rusty pickup trucked picked them up.. every seat I put out there by the curb was gone that night..
Old 10-16-2017, 04:00 PM   #17
Scrappers came for our seats as soon as we pulled them. Didn't even have to haul em to the curb.
Old 10-16-2017, 04:37 PM   #18
Traveling
Rated Cap: '00
No more scrappers by me. They require them to have a Refuse License now else big fine.
Progress....
Old 10-16-2017, 05:23 PM   #19
Progress....
IS there any visible reduction in the meth head populace? If so, then that's a win.
Old 10-16-2017, 05:25 PM   #20
Traveling
Rated Cap: '00
Meth is so last year. We have Heroin around these parts.
