Old 02-19-2007, 07:37 PM   #1
KC10Chief's Avatar
Rated Cap: 60
Bus seats! What can I do with them?
I worked for 5 hours tonight on stripping seats from my bus. I started in the back and got 8 of the 20 seats out! I might have been able to get more seats out, but it was a nice day and the neighbors were out stopping by asking questions. About 2 hours of that was probably spent BSing. These seats are a real PITA to get out! Bolt heads on top inside the bus, and nuts underneath. I loosen them up if I can and then just angle grinder them out. I remember when I was a twerp little kid back in the day and I used to tear up seats or shoot spit wads all over the bus. What goes around comes around and I guess I'm getting what I had coming to me. Anyways, I tore all of the foam off the seats and put it out for trash day in the morning. I'm going to take the metal down and sell it for scrap unless anybody can suggest a use for it. There's lots of metal tubes and sheet metal on the back. The sheet metal isn't in the best shape though. It has lots of cracks in it or it's dented or whatever. Anybody got any ideas? Thanks! Matt
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
http://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 02-19-2007, 08:20 PM   #2
the_experience03's Avatar
I tried for a long time to think of a use for my seats, but in the end the plywood was put on the burn pile, the foam and vinyl went to the dump, and the steel went for scrap.
Old 02-19-2007, 09:10 PM   #3
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
I remember someone using the old foam, for their comversion. Forthe life of me, I can't remember who.
Try Vonslatt, I think he might have found some use for them.
Roasting8 is offline   Reply With Quote
Old 02-19-2007, 09:22 PM   #4
I was going to use mine for the beds (I think Jake used his for the dinette), but they smelled too much like....well...bus.
Old 02-19-2007, 09:55 PM   #5
oldog12's Avatar
Try giving them to the local bus barn, if they can use them, or need them, you score some points with them that could come in handy down the road...
oldog12 is offline   Reply With Quote
Old 02-19-2007, 10:19 PM   #6
GoneCamping's Avatar
I was gonna try using the stuffing for carpet padding, but decided it wasn't worth trying to piece them all together. Everything went in the trash dumpster except for the frames...they went to the metal recyle place for a couple bucks of pocket money!!
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 02-20-2007, 02:15 PM   #7
That is worth noting. On my bus, atleast, the seat bottoms were identical and then just either had a left or a right side of aisle legs bolted on with clamps. You could bolt a set of right and left side aisle legs to a seat and it would be free standing without the need for that rail that runs along the outside.
Old 08-04-2019, 12:34 PM   #8
I know nothing about welding or if the metal would be strong enough for this, but could you use the metal to make one of those storage compartments at the bottom of the bus, and then just add sheet metal to it to make a box?
H.Gilly is offline   Reply With Quote
Old 08-04-2019, 01:06 PM   #9
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
yes you could.
get you a small welder and practice yourr fabrication skills with half of the frames
learn a valuable skill set and use the other half to make storage bins underside and scrap what you dont use
the feet with the mounting plates would make good attachment points to the bus chassis body to keep from having to weld on the chassis or bogy ribs underneath
if nothing else plenty of scrab to chop up and learn welding and fabrication skills whether you actually use the material on your build or not
you learn a skill that will help in areasof your build at some point and you can still take the scrap to the dump when your done playing with it
Old 08-04-2019, 07:27 PM   #10
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
If one had the time they could join a left and a right together and after an hour they would have a crappy love seat that no one wants and they will have wasted an hour and still have to haul the remains to the scrap yard, bus seats served their purpose before their sale to us and in my estimation and many others on here are best left to the scrapper. Gene
Gdog 5651 is offline   Reply With Quote
My seats are gone! Hearse Driver Skoolie Conversion Projects 1 03-10-2009 10:40 PM
Seats.... drchefscott Skoolie Conversion Projects 3 02-04-2009 05:36 PM
looking for seats! TikiBus Classifieds | Buy, Sell, Swap 3 01-31-2009 03:28 PM
New Bus seats somecards Classifieds | Buy, Sell, Swap 3 09-15-2008 11:25 PM
Seats.....no, not the bus ones...... Vern1 Conversion General Discussions 3 02-24-2004 03:43 PM
