Old 10-12-2008, 10:15 AM   #1
Lady Franklin's Avatar
Engine: 7.3 International Diesel
Re: Building a under bus storage box with an old locker
Well if it were me I would use my grinder with a zip cut blade in it to cut the hole. They are just able to cut such a nice line compared to the recip saw. I have cut with a sawzall but only where I am going to cover it up again because it is so rough and hard to control. As for your little braces and how to attach it, I would weld that sucker right in there. I would weld it to the sheet metal and the floor joists then the locker takes the place of your little metal tabs holding the sheet metal. Alternatively I would do as you mentioned with U-Bolts but I would also put little metal 45 degree angle brackets all around from the locker to the sheet mental to keep it sturdy otherwise your sheet metal may move around a little too easily. Post some pics when your done I would love to see it!
Lady Franklin is offline   Reply With Quote
Old 10-12-2008, 09:43 PM   #2
lapeer20m's Avatar
for cutting sheet metal, i also like to use a standard 7 1/4" circular saw like you'd normally use for cutting 2x4's or plywood. I put a metal cutting abraisive blade on the saw. I find this to be one of the easiest methods for cutting a straight line in sheet metal.
like mentioned above, the skinny abrasive cut off blade on an angle grinder is also a great solution.
I'm all about safety 3rd, but with either of the above methods, don't for get to wear ear, eye, and breathing protection. Lots of small glowing red hot flying metal particles, dust, etc flying around and it is surprisingly loud!
I have certianly used a sawz-all and have the same problem of not being able to cut a straight line. Ugly cuts can be made with a torch, or even an arc welder with the heat turned most of the way up...not something you're gonna do on this project, but just thought i'd throw those out there. I like cutting things with my arc welder when neatness doesn't matter. I've even cut through 1/2 inch plate. someday i want to own a plasma cutter......
Old 10-13-2008, 12:00 AM   #3
phillbus914's Avatar
Great idea. A friend of mine offered me some old school lockers a while ago but I couldn't think of what I'd do with em. I'm going to see if he has them still now.
My Old Bus :(
Old 10-13-2008, 06:52 PM   #4
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Nice job! Wish I could find a couple of those. . .
Griff is offline   Reply With Quote
Old 10-13-2008, 06:55 PM   #5
that looks great and it's the perfect width (height now)
nice work...
My Old Bus :(
Old 10-13-2008, 09:28 PM   #6
the_experience03's Avatar
Originally Posted by bender477
rob a mercury switch off a car hood to make it turn on when the door is up .
First of all...pure awesomeness. I've been wanting to do just this mod for some time now, but just haven't stumbled across any lockers.
As far as a switch goes...I would just get a generic door jam switch. Get one that controls ground and you'd be all set. They're cheap and any parts store worth a warped rotor will have a big rack full of Motormite Conduct It! stuff.
Old 10-13-2008, 09:51 PM   #7
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
and rob a mercury switch off a car hood to make it turn on when the door is up .
Or from an old house thermostat ...
Hex is offline   Reply With Quote
Here you go PDBreske......my safari pics..lots of pics bansil Everything Else | General Skoolie Discussions 2 09-05-2012 04:17 PM
Lots of bus pics frank-id Everything Else | General Skoolie Discussions 3 03-14-2011 12:11 PM
Looking for some pics of a skoolie frank-id Everything Else | General Skoolie Discussions 1 01-31-2007 04:42 AM
new bus pics in gallery westport_wayne Everything Else | General Skoolie Discussions 1 09-14-2006 11:07 PM
I Finished my Bus ! (pics) vonslatt Skoolie Conversion Projects 11 08-18-2006 09:49 PM
