05-04-2017, 11:00 AM
#101
I thought I had some better pictures of the Wagon. Appologies for the thread drift.
Robin
Nobody's Business
05-04-2017, 11:07 AM
#102
You should be asking Rust-oleum if they will sell to you in the barrel size.
05-04-2017, 12:00 PM
#103
I should ask Rustoleum to replace the paint on that Power Wagon. In this coastal weather the paint seem to peal off in large chips.
I'm actually making an effort so my bus doesn't peel like that.
Robin
Nobody's Business
05-04-2017, 12:25 PM
#104
I assumed it was the original paint. You didn't use a latex did you?
Some internet chicky followed the H.D. dude's advice and used an interior/exterior latex paint. Maybe for the floor where you're trying to water proof it? There's better products for that too tho. Anywho, the dead bugs stain the latex and it peals. Go figure.
3 days and it hasn't peeled yet!!
05-04-2017, 12:47 PM
#105
Boy, this thread went all over pretty quickly!
For the record, a venturi bead breaker:
BOA Constrictor® | Gaither Tools
Also of interest on the 'Tube would be some slo-mo movies of rail rods getting off the line that I ran across at some point. (Amazing what they suggest might be interesting to you.) The tires assume shapes that their mommas never intended them to assume.
05-04-2017, 04:02 PM
#106
Originally Posted by Rameses
Bias ply tires will get flat spots if parked for a while without being moved. The flat spots will work themselves out once the tire is heated up on the road, but until they get warm it'll be a rough ride.
How long is a while?
05-04-2017, 04:39 PM
#107
If it's cold outside, expect things to smooth out about 15 minutes down the road. Faster in warm weather.
Robin
Nobody's Business
05-04-2017, 06:05 PM
#108
I can handle that. My Mazda 5 is the same way. Go figure. Thank you.
05-04-2017, 06:14 PM
#109
my silverado truck (2015) definitely gets flat spots.. granted that truck sits more than it drives but I think any tires will give you flat spots from sitting, esp in cold weather
05-04-2017, 06:30 PM
#110
Depends on several factors.
If it's cold outside, no sunlight to heat up the asphalt, and you're driving extremely slowly, they'll take a really long time to warm up.
If it's blistering hot out, sunny with 140 degree road temp, have low tire pressure, and are driving like a maniac and weaving back and forth like a NASCAR driver trying to keep their tires hot, you'll probably get them up to temp in about a minute.
Realistically, yeah, probably about 15 minutes under average real world conditions.
05-04-2017, 07:04 PM
#111
I appreciate the info. I live just north of Gainesville, Ga. It doesn't get too cold here.
05-05-2017, 08:28 AM
#112
have low tire pressure, and are driving like a maniac and weaving back and forth like a NASCAR driver trying to keep their tires hot,.
Really? If a NASCRAP car turns right, it wrecks!!
IRL, F1, IMSA, WRC, etc.
Dave,
It happens a LOT with real tires. Tires with a treadwear of 200 and less. They don't like cold weather, even your version of it. Truck tires and 110 PSI I don't know. Leave your bos for 6 months without moving it and it will flat spot. 6 weeks. Maybe? 6 hrs. No. Where the line in the sand is, I've no clue.
05-07-2017, 07:56 AM
#113
Chassis: B3800 Short bus
If anyone cares, I posted an update on the front end progress on my build page: http://www.skoolie.net/forums/f27/ar...tml#post202129
Kingpins are installed now I'm on to the tire swap! I'll have to visit the neighbour's to borrow a tire iron. There's one around here somewhere, but I can't find it...
05-08-2017, 07:25 AM
#114
Originally Posted by jazty
I'll check that out in a minute.
1 5/16ths or 33mm.
05-08-2017, 07:34 AM
#115
Originally Posted by Brewerbob
1 5/16ths or 33mm.
Oh, I was speaking of this kind of tire iron.
I have a socket for taking off the lug nuts (1 1/4"), but I'll need to borrow one for the axle nut (1 5/8"), since it appears that I need a new left axle seal as well. Popped the covers off to check the grease and found a bit of water in the left hub. The bearings are fine, though. No deep water infiltration has occurred quite yet.
05-08-2017, 08:31 AM
#116
Totally read that as lug not tire. My bad.
Really? I couldn't find a 33mm so I bought 1 5/16". There's a tad of slop. More than I'd like but seeing how mine are painted, probably a good thing. Also as it is 6 poiint and not 12, it shouldn't matter. Pretty sure I tried the 1 1/4" and it didn't fit.
Hob centric on mine. You?
05-08-2017, 08:40 AM
#117
Good ol' Daytons!
I like 'em, personally. I can change a tire on the side of the road, or down my dirty driveway. Also the tires + rims are lighter than the other variants. I can even lift a dismounted tire if I wrap my arms through the center.
05-08-2017, 08:45 AM
#118
Good ol' Daytons!
Had to google that. Mine definitely are NOT. And unless they make them in a 10 lug pattern, they aren't going to be any time soon either.
05-08-2017, 08:50 AM
#119
Daytons use an 1 1/4" socket, hub piloted use 33 mm, and stud piloted use 1 1/2".
Good ol' Daytons!
My grandfather could load one in the back of a truck by letting the tire tread rest against the front of his hips and grabbing the inside of the rim with his fingers. He'd pick up with his fingers and hold the tire out in front of him in a horizontal fashion and walk it over the tailgate and sit it down. To this day I still have no idea how that's even possible.
05-08-2017, 08:51 AM
#120
Switching from your wheels to Daytons requires changing your hubs.
