Old 07-11-2018, 04:40 PM   #1
Kandall's Avatar
Bus won't start
1993 international bluebird
Mechanical DTA466
Preface:
We removed the rear heaters, keeping the front drivers side heater, but we forgot to shut the coolant valve next to the engine, although we did manage to shut the valve next to the driver-side front heater. Forgetting to shut the valve next to the engine could be the issue here but were not sure how to fix it if that is actually the case. The coolant line is currently looped on the left rear side of the driver seat.
We drained a little over 5 gallons of green coolant from the heaters. Since then we've added about 2 gallons of orielys brand green coolant to the radiator, the radiator appears to be full now.
The current issue:
Now when we turn the ignition without trying to actually start the bus, the "oil/water" light comes on.
Then when we turn the ignition all the way to try to start the bus, the "water in fuel" light comes on and nothing happens.
Kandall is offline   Reply With Quote
Old 07-11-2018, 05:11 PM   #2
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Iím not an expert on that exact situation but it sounds like there may be a sensor that is telling the computer if it there is not coolant in the system and therefore that prevents a start. Also it sounds like maybe the water separator needs to be drained.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 07-11-2018, 05:13 PM   #3
Chassis: Thomas
Engine: CAT 3126
Sorry, just reread and saw that yours is fully mechanical so it would not have a computer. Regardless there may be sensors preventing a start.
My Build Thread:
Old 07-11-2018, 05:26 PM   #4
Kandall's Avatar
Originally Posted by david.dgeorge07 View Post
I’m not an expert on that exact situation but it sounds like there may be a sensor that is telling the computer if it there is not coolant in the system and therefore that prevents a start. Also it sounds like maybe the water separator needs to be drained.
You think it's a bad sensor? Any way to find out for sure? At this point should we keep all the valves shut or closed?
We've tried draining the seperator; we found a filter under the hood next to the engine, that filter has a transparent bottom on it, with a peacock under it. On the filter it says "drain regularly to remove water", so I'm pretty sure that's a seperator. We drained as much as we could, came back later and it filled itself back up even tho it hasn't actually started, so I've gone back and drained it about 3 times now. I think there maybe an other separator somewhere along the fuel line, I'll have to get under the bus to hunt it down.
I'll try to post some pics tonight
Old 07-11-2018, 05:45 PM   #5
Chassis: Thomas
Engine: CAT 3126
One drain of the separator should be fine. In fact you usually only need to drain partially to remove water (will be at the bottom). If it is empty then you have no fuel.
As far as valves open or closed, I think that you should have all valves that went to accessory parts closed. If there are any valves that appear to shut off some section of the primary cooling system than that should be open but as far as I know thatís not a common thing.
You may need to bleed the cooling system. Often times in one of the upper lines there is a petcock that you can open when adding coolant that allows air to escape. If it doesnít have one of those you may need to disconnect one of the upper lines to allow air to escape. Itís possible that an air bubble is keeping your system from filling up, even though the radiator is full.
My Build Thread:
Old 07-11-2018, 06:08 PM   #6
Chassis: Thomas
Engine: CAT 3126
Not sure how many heaters you had, but when I took mine out I donít think I got 5 gallons out.
You may want to consider doing a full flush and fill if you donít know when it was last done. Then you can fill based on a factory spec for capacity to know if you are in the ballpark or if there are bubbles. You probably need to change your coolant filter as well. If the PH is off it will start corrosion in you engine.
I imagine you really want to solve the starting issue right away and that may seem like a side project, but it will need to be done and you are already knee deep in it.
Hope you solve soon!
My Build Thread:
Old 07-11-2018, 06:16 PM   #7
Kandall's Avatar
We havnt been able to find a bleeder valve or a petcock to get air to escape, if it turns out to not have one, what upper line do we disconnect, and where?
Thanks so much for trying to help!
Old 07-11-2018, 07:48 PM   #8
brokedown's Avatar
I'd think on a mechanical bus you're looking more for interlocks than anything. Not a lot of things should prevent the starter from spinning. If it was spinning and not firing up that would be a deeper dive but there should only be a few things preventing your starter solenoid from triggering the starter to spin.
Do you have the wiring diagram for your bus?
Old 07-11-2018, 08:40 PM   #9
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Engine: DT 466e/MT 643!
Rated Cap: 16
When my bus would not start, the same lights came on. It ended up being the starter...
johnbloem1974 is online now   Reply With Quote
Old 07-11-2018, 08:54 PM   #10
HappyInTN's Avatar
Chassis: Genesis
Rated Cap: 84lug
Mechanical DTA466
Preface:
The current issue:
We did the exact same thing with our heaters. However, our dt466 cranked back up just fine. The oil/water light now blinks and there is a beeping sound (very annoying) but it runs and drives great. I just assumed I needed to take it to an international dealership or a commercial diesel mechanic to have the sensor/light reset.
Serenity Bus Project - Our website/blog & Youtube www.serenitybusproject.com
https://www.youtube.com/channel/UCcH4RThGB-Hw9fUirF836rQ
I write Skoolie insurance policies in TN/GA now AL & MS also!https://www.skoolie.net/forums/f18/i-can-get-your-skoolie-insured-in-tn-ga-22233.html
HappyInTN is offline   Reply With Quote
