Old 06-09-2019, 03:15 PM   #1
Year: 87
Chassis: Ford B700
Engine: Detroit Diesel 8.2L "Fuel Pincher" V8
Bus won't start: How to I open this door to the batteries?
Hi! PLEASE ADVISE
Road Sloth is finally title in hand, street legal, and registered but now she won't start! I think it's as simple as dead batteries but I can't open this door to access the batteries. Please see photos:
(I don't known why the 2nd pic loaded sideways)
Thank you!
Stacy
Road Sloth is offline   Reply With Quote
Old 06-09-2019, 03:18 PM   #2
Are the holes on the right latches? Look inside this holes to see if there’s a slot
Old 06-09-2019, 03:46 PM   #3
Year: 87
Chassis: Ford B700
It's so hard to see in there. Not very open but I'll check rn. Thank you
Old 06-09-2019, 03:49 PM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
May be bolted closed with carriage bolts. Can you see if there are nuts on the back side of the skirt you can access?
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 06-09-2019, 04:58 PM   #5
Try a screwdriver in there to unlock them.
Old 06-09-2019, 05:18 PM   #6
THis^
If you get no satisfaction that way grind off the rivets.
Old 06-09-2019, 05:26 PM   #7
Year: 87
Chassis: Ford B700
No visible nuts, looks locked down. See pics:
Thanks!!
Old 06-09-2019, 05:49 PM   #8
Year: 87
Chassis: Ford B700
There is nothing behind the holes and screwdriver didnt work
Are the batteries somewhere else? Thomas chasis 87 Ford B700 DD 8.2L
Thanks for helping!
Old 06-09-2019, 05:53 PM   #9
Chassis: Thomas
Engine: CAT 3126
Thanks for helping!
Pretty sure that is the right location. There’s got to be a way to open the door. A release handle inside the cabin maybe?
My Build Thread:
Old 06-09-2019, 06:11 PM   #10
Thanks for helping!
Try inserting a 3/8" ratchet extension in the 2 holes and turn ccw.
Good luck
Old 06-09-2019, 06:16 PM   #11
Thanks for helping!
Tap on the bottom of the box, does it sound hollow, or like a thud because the weight of batteries is on it?
Old 06-09-2019, 06:18 PM   #12
Year: 87
Chassis: Ford B700
It's open! Yes! Flat head screw driver in the holes and turn it to the right - my first screwdriver was too short!
Thanks so much for helping!!!
Old 06-09-2019, 07:00 PM   #13
That'll be $4910 please. $10 for knowing where to put the tool and $4900 for knowing what tool to use. .
Old 06-09-2019, 09:06 PM   #14
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
If the hole inside is square, the tool is a T handle with a tapered square. Most any thing that fits the hole closely should work.
Old 06-09-2019, 09:11 PM   #15
Only two batteries?
Old 06-09-2019, 11:16 PM   #16
Only two batteries?
Usually more than two for starting the bus isn’t a thing. I think the house batteries are somewhere else, these must just be for starting. Correct me if I’m wrong.
JoeNesquik is offline   Reply With Quote
Old 06-09-2019, 11:55 PM   #17
My Genesis with a DT466 came with only one Group 31 start battery.
Old 06-10-2019, 12:58 AM   #18
HazMatt's Avatar
Chassis: IH 3800, 8 window
Kudos on wrinkling open your battt hatch!
Welcome to the Looney tunes sdulumz!
Old 06-10-2019, 03:09 AM   #19
Only two batteries?
I can run just one.
Old 06-10-2019, 08:33 AM   #20
Well, my bus came with three batteries and the tray is clearly designed to hold three of them. Having just bought and installed three replacement batteries, I'm interested to know whether I could have bought just two or one instead.
