Old 04-20-2009, 08:52 AM   #1
Year: 93
Chassis: ?
Buying a bus TODAY
going to look at somebuses today.
Blue Bird and Thomas with exact same drive train and length.
Which one is the preferred model? Why?
I will have one or the other by 12 noon today.
Thanks for your quick replys.
swhite832 is offline   Reply With Quote
Old 04-20-2009, 10:28 AM   #2
lapeer20m's Avatar
Re: Buying a bus TODAY
I've had at least 2 thomas body buses....as a matter of fact, i'm typing this message from inside a thomas bus right now. I have nothing negative to say about thomas buses. I think that the general consensus is that Blue Bird buses are a little higher end than your average skoolie. I would not make a decision based on thomas vs bluebird necessarily. With engines and transmissions being equal, i would look at other things like:
Rear end gear ratio. the lower the number the better ie: 4.44 is way better than 5.57. You can usually crawl under the bus with a paper towel or wire brush and clean off the tag on the axle to find the gear ratio. This is a HUGE thing when it comes to top end speed and fuel economy
Inside Height
Air or juice brakes? Air brakes are nice because it's cool to run air tools and the like. Hydraulic brakes work fine though, and are easier for regular non-bus people to drive.
Mileage...the lower the better obviously
then there are other features like rust, underbelly storage, tinted windows, air ride driver seat vs fixed drivers seat, etc
Old 04-20-2009, 10:43 AM   #3
Year: 93
Chassis: ?
Thanks. Great info. Anything else
Meaning blue bird higher than Thomas?
Old 04-20-2009, 03:43 PM   #4
NewSkewlHauler's Avatar
Engine: 8.2L Detroit N/A, Allison
This is probably too late to help...even with that said, it's probably not too much help anyway.
I was talking to our bus barn manager awhile back about the differences between Blue Bird and Thomas. He said that they were of equal quality, but that Blue Bird was just overpriced...his opinion. I think that everyone has their preferences. I'm a track and cross country coach and I prefer Asics to Nike, although Nike are generally higher. I've had MUCH better luck with the Asics shoes than I ever have with the Nike...and my son has destroyed the few pairs of Nike that he's had. But that's neither here nor there...
BB's have the little "eye" think over the windows which may be problematic depending on what you intend to do with your bus. I think there is a post somewhere that someone "solved" that problem of what to do with the eyelids. With all things being about equal, look at what you're going to use your bus for and what advantages would one present over the other...if none, flip a coin!
Best of luck! Let us know how it came out.
NewSkewlHauler is offline   Reply With Quote
Old 04-20-2009, 11:54 PM   #5
Year: 93
Chassis: ?
Bought the Thomas....
I had three buses to look at. The Bird was the preferred because it was 2" taller inside and I like the way the front looks. It had a signicant leak at the rear main bearing of the tranny. The leak had been there awhile. I did not like the location of the fuel tank. It had ~148000 miles. The two Thomas's were clean one cleaner than the other. I ended up with the one that had a slight oil leak via valve cover. I just had a better feeling about it after poking around them for a hour. The Thomas has all kinds of room underneath vs. bluebird. Kudos to the owner who was very patient with me. In two weeks I go get it to drive it back. The wife says i can't park it at home.
Thanks for all your opinions.
Old 04-21-2009, 02:34 AM   #6
swinada's Avatar
Congratulations on your purchase, and hopefully you will have many happy hours with it.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
http://picasaweb.google.com/swinada/BusPictures http://www.swinada.com/bus.htm
http://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 04-21-2009, 04:17 AM   #7
Do yourself a favor. Before you start work on it, Prick your finger and put a drop of blood somewhere in/on the bus.
I read several posts that the "Bus God" demands blood, and if you dont offer it, He will make you give it...
Old 04-21-2009, 08:40 AM   #8
Year: 93
Chassis: ?
Thanks for all the help....Now i have to acquire all the STUFF to put in it.
Old 04-21-2009, 02:00 PM   #9
Chassis: International Cornbinder
Nice bus. Looks alot like my 1993 AmTran/International I bought saturday. What motor does it have in it? Driving back from Kentucky I was able to get 65mph out of the bus easily on flat ground.
gotmuddy is offline   Reply With Quote
Old 04-21-2009, 10:01 PM   #10
Year: 93
Chassis: ?
It has the cummins 5.9, AT545, unknown rear end. It probably won't get over 55-60.
I recognize your bus. Those boxes built in are a real plus. I talked to the guy selling it and came extremely close to bidding on it. The drive home was too far for me to commit.
The guy I bought from sold one on ebay that i bid on and lost because I went to sleep. He had three others 4.5 hrs away. I got to look at all three pretty close before making the decision which was a real plus. The BB had a significant leak. One of the Thomas's had a bad alternator and the other a minor valve cover gasket. I took the one with the leak because it just looked better taken care of.
At any rate the wife says I have to keep it somewhere else. I told her that if I was going to be white trash I had to give it 100%. She is not buying it. I bring it home May 3rd.
Old 04-23-2009, 12:54 PM   #11
The drive was kind of a plus for me. It gave me a great time to learn how to drive a bus. I now feel I could drive anything
On a side note, There is a 96 model amtran(I believe) for sale in Nixa, MO. I ordered parts for mine and he was telling me about it being a good deal at $2000....but its got over 160k on it and its a dt444(7.3L psd). I dont think I want to buy a bus with a tranny that has 160k on it.
Old 04-23-2009, 02:22 PM   #12
Year: 93
Chassis: ?
I can understand that. The bus I have has probably 150000. I am from the school of thought that a fleet bus from a school probably has had fair maintenance. The at545 is speced out so much because it has a bullet proof reputation. It is always better to have less miles but the right equipment with decent maintenance will go forever.
Any ideas on what your going to it?
Old 04-23-2009, 03:33 PM   #13
I am used to truck trannies. My truck is a 1996 for psd with 305k and its in great shape
My wife and I are going to convert it into a ultimate toy hauler. A build thread will be coming this weekend.
Buying a bus tesswynn92 Skoolie Conversion Projects 10 08-13-2014 05:24 PM
Buying first bus! cschlessman Conversion General Discussions 1 06-22-2012 05:35 AM
After buying... LOrOLR Conversion General Discussions 4 09-08-2009 02:33 AM
Buying a first bus gmkdart Conversion General Discussions 1 08-03-2008 04:00 PM
Buying Bus code4 Skoolie Conversion Projects 18 10-23-2005 05:40 PM
