Old 11-24-2017, 05:58 PM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Cadilac kid
Gonna be I Columbus Sunday and would love to meet up. Maybe get my cruise control on and go faster than 65 mph. Is there a private message on this site? Seems like there should be.
Sent from my LG-LS777 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 11-24-2017, 07:03 PM   #2
hey there.. i should be in town!.(putting up christmas lights at my house... lots of them..) yeppers you can send a PM on this site. im on the browser on my phone (I broke my tapatalk damnit.. gotta fix it..).. otherwise id shoot you a message..
I reprgroammed Hazmatt's computer on turkey day, he ought to be in texas about now!!
I can only get you faster than 65 if you arent out of gears.
Old 11-25-2017, 08:55 AM   #3
Coachwork: myself
Chassis: amtran
It won't go over 67 even down hill. It makes a noise like the u joints are going out (sort of) when out maxs out. And the cruise control doesn't work. I had someone mess with it before, but i don't think he knew what he was doing
Old 11-25-2017, 09:01 AM   #4
what RPM are you hitting at 65? I had a center carrier bearing rubber retainer all rotted out on mine that caused it to make nasty sounds at higher speeds.. the driveshafts were vibrating in that rubber retainer..
we can cewrtainly look at your cruise and see if any codes are being set too. the cruise will be disabled if any fault is detected in either of the 2 brake light switches.. i had an issue on my red bus where in heavy rains my cruise would quit.. turns out i had water dripping onto the brake pedal switches and caused one of them to fault..
however its quick and easy to hook up the computer and take a look.
Old 11-25-2017, 09:03 AM   #5
Coachwork: myself
Chassis: amtran
It only makes the noise when i am going down hill faster than the diesel can push the bus. It won't go faster than 67 no matter what
Old 11-25-2017, 09:04 AM   #6
Coachwork: myself
Chassis: amtran
I can let of the pedal and it stops
Old 11-25-2017, 09:07 AM   #7
sounds like what mine did.. if you are up at 2650 RPM or so then you are maxxing the engine RPM.
Old 11-25-2017, 09:08 AM   #8
Coachwork: myself
Chassis: amtran
Around 23 or 24. Never over 25
Old 11-25-2017, 09:09 AM   #9
should still have some room left for a few MPH then. awesome
Old 11-25-2017, 09:17 AM   #10
Coachwork: myself
Chassis: amtran
Awesome. I can't wait. I hope there isn't a prob worth that bearing. I won't take up much of your time either. We have a show Monday in Charlotte. Thank you in advance
Old 11-26-2017, 08:25 AM   #11
Coachwork: myself
Chassis: amtran
Was wondering when a good time to come by was. And where You are at. You can text me on my phone. 720 989 9166
