Old 04-01-2016, 03:27 PM   #21
turf's Avatar
R14 when a quarter your surface area is single pane window is an unreasonable number.
i think r4 was wishful thinking in my situation.
good luck
Turfmobile Build Thread
Old 04-01-2016, 04:46 PM   #22
RHOMBUS's Avatar
Chassis: Freightliner HDX
Engine: CAT 3126B250
Use this for a quick reference and you'll see that volume is much much more than twice as much square footage:
BTU Calculator
For my bus, a 40 foot bus, that will have 6 double paned windows, the windshield of course, everything else sheeted over, 2 inches of closed cell spray foam in the ceiling and walls, 3/4" foam board on the floor, an not accounting for dead spaces like cabinets and barriers like the bathroom and bedroom walls, it comes out to the following:
Width: 7.5 feet
Length: 35 feet
Height: 6.1 feet
Insulation condition: normal - you are still in a metal box, which can be a cooker or a freezer
Temperature change: 80 degrees F - assuming at -20F outside worst case, and 60F inside
24,992 BTU/hour
I'm looking at getting a Webasto diesel fired heater that will do a little over 20kBTU on its max setting and am still concerned that it may be too cold to endure. Since it says you're in Chicago, I imagine it gets cold there in the winter. If you stay in an apartment, with other apartments above, below and on each side all running their heaters, it's absolutely nothing like being in the bus surrounded by the raw air. Just like metal conducts electricity, it conducts heat - from where it's hot to where it's not. You'll freeze in the winter unless you camp directly in front of that 600w heater.
Like you said though, real life will show the way. Pack lots of blankets and a fire extinguisher.
My project: The Cruel Bus
RHOMBUS is offline   Reply With Quote
Old 04-01-2016, 08:25 PM   #23
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Rhombus, remember that is a start up from -20 to 60. Once the cabin is heated and your cabinets and furnishings come up to temp the heater will not need to work as hard, providing there are no air leaks. While single pane windows do lose a lot of energy, a simple sheet of .05 mil tint will help it out a lot plus say a small curtain to help hold heat or cold in, whichever you are using.
Look at it this way, on an electric stove, the element is hottest when you are warming up the water to boil, once it is boiling, it doesn't need maximum energy from the element to maintain it. Adding a lid to the pot helps it heat faster and maintain its temp.
Old 04-01-2016, 08:53 PM   #24
Chassis: IC CE
Engine: T444
good luck
yeah, i think double pane will be a requirement or as they said the tinting.
Either way i will have to adjust a bit in my budget and planning. Score one for over thinking lol
Azuleslight is offline   Reply With Quote
