Old 04-13-2017, 02:18 PM   #1
Can a King sized bed fit in a bus?
Hello fellow skoolies. Has anyone ever tried fitting a king sized bed in their bus before? We don't mind having our bedroom literally just a giant bed with shelves above us.
I ask because we invested in a king sized bed about 6 months ago, a really nice one, and would rather just keep using it when we move into our bus, since I imagine selling a used bed is difficult, and certainly don't think we could get back what we spent on it.
Thank you for sharing your thoughts!
chickadee020 is offline   Reply With Quote
Old 04-13-2017, 02:56 PM   #2
Robin97396's Avatar
Nice idea. Honestly I think I'd go with a set of twin beds pushed together.
If you can get it through the door you've got it made.
Robin
Nobody's Business
Old 04-13-2017, 03:03 PM   #3
Rengald's Avatar
Rated Cap: 71
Unless I am mistaken, a king size bed is 76" x 80". So... it "should" have no problem fitting once it's inside but there won't be much room left over around it.
A king size bed can use two extra long twin box springs side by side as base and those would be a lot easier to move inside than a large king size rigid box spring. Most mattresses are pretty flexible so I would think you could get that inside too. Maybe not the easiest thing but certainly plausible.
Rengald is offline   Reply With Quote
Old 04-13-2017, 03:19 PM   #4
Chassis: Blue Bird
Engine: ISC 8.3
I'm not sure if you mean "fit through the door" (which door?) or simply "fit flat down on the floor" once it's inside.
Lots of people have a queen bed oriented so the head and feet are toward the bus sides. My Blue Bird is something like 90 inches wide on the inside, before adding insulation etc to the interior of the wall, so there is as much as 10 inches extra for fitting an 80" tall mattress. King is the same height and so would fit the same way; it'd just take more length in the front-to-back direction of the bus.
Obviously if the king-size bed is shared and arranged across the width of the bus there'll be some climbing over one another for midnight snacks or bathroom trips, so consider whether there'll be any objection to that. If you laid on it along the length of the bus then you couldn't roll out sideways off the bed, which may or may not be problematic depending on physical condition (agility, flexibility, weight, strength, whatever).
Old 04-13-2017, 03:33 PM   #5
The bed has these two (twin sized) base pieces, so at least that part is covered. I was excited about the idea of being able to store stuff underneath the bed, but I may be asking for too much here.
Old 04-13-2017, 03:34 PM   #6
Thank you for the info and thoughts, family wagon! I'm relieved to hear you think we could get it through the door. And as far as thinking about long-ways versus sideways is definitely good food for thought as well.
Old 04-13-2017, 03:57 PM   #7
As others have said: Yes it will fit once you have it inside provided you don't mind not having space to move around the sides.
As far as getting it inside, that can be a challenge. I have replaced two mattresses in RV's lately (last two years). One of them had a queen mattress that we had to cut apart to get it out of the bedroom.
Fortunately for me I found a VERY easy to "install" replacement mattress. It is a "Gel" memory foam mattress. Probably the most comfortable mattress I have ever slept on. Not only that but it arrived "vacuum packed" and fit very easily through the doors. Unpacked easily. We simply cut open & removed the vacuum bag and let the memory foam recover its shape.
I have been sleeping on one of those nightly for almost two years and still love it. It is more comfortable than my old $1100 mattress at less than 1/3 the price.
Old 07-25-2017, 01:33 PM   #8
Ive had success with using multiple ratchet straps around a mattress to squeeze it through tight spots.
Escaping the rat race and LIVING.
Freedom30 is offline   Reply With Quote
Old 08-05-2017, 04:29 PM   #9
Can you tell us where you got the mattress ??? Thanks.
45acp is offline   Reply With Quote
Old 08-05-2017, 09:18 PM   #10
A little bit off topic, but not much...
My queen mattress & box springs is turned cross ways in my bus.
I spanned 3 or 4- 6" wide C-Purlins across the chair rails... Couldn't be happier! Solid and no squeaks.
This way, nothing was permanent.
I was in Walmart a couple nights ago, and they had those memory foam mattresses made by Zunis.
They seemed very affordable and had good reviews.
If I went to that, I could still use my C-Purlins and just add an 2x2 angle iron ledge at the height I wanted.
Still apprehensive about buying a memory foam mattress... What if I don't like it or it makes my back worse?!?!
Edit; just called my local Walmart, spoke to customer service... She said there's no extra policy for memory foam mattresses, and I could return it within 90 days as long as I kept my receipt. I even pointed out it's vacuum compressed in a box, and would be returned uncompressed... She said no problem.
C-Purlin:
bedroom, fitting, king sized bed, shelves, size
