Old 07-02-2014, 04:13 PM   #1
Engine: DT466 Allison
Can I removed the lower inside walls?
Do these come off or are they necessary to keep?
Photo below
http://s47.photobucket.com/user/Alexlor ... 5.jpg.html
Alexlorraine01 is offline   Reply With Quote
Old 07-02-2014, 05:42 PM   #2
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Re: Can I removed the lower inside walls?
Photo below
I was planning on pulling mine as well and replacing with beadboard and ply over insulation. As long as you don't cut out the chair rail, you should be fine, since that's what mates the floor with the body.
Captain Obvious on deviantArt
Old 07-02-2014, 07:24 PM   #3
I wanted to take out the chair rail... thinking I couldn't. How do you suppose I cover it up? Build over top of it?
Old 07-02-2014, 08:00 PM   #4
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
Build around it with cabinets and as a mounting point for both cabinets, bulkheads and use it as part of your cable and plumbing chase. But it has to remain in place, since its a major structural component of the bus.
What to do with removed seats? Pyracantha Conversion General Discussions 6 04-10-2012 12:53 AM
Anyone removed the Ridged Rub Rails? What's behind there??? usmcbay Conversion General Discussions 3 03-29-2012 03:20 AM
R u considering a bus conversion (N NJ or lower NYS)? wirelessguyNY Classifieds | Buy, Sell, Swap 0 09-22-2011 06:37 PM
Do I really need the lower AC unit? Diesel Dan Conversion General Discussions 9 08-24-2010 12:35 PM
Lower 48 to AK........ dlor1 Everything Else | General Skoolie Discussions 6 05-30-2008 03:19 AM
