Old 01-15-2016, 07:21 AM   #1
Arvik's Avatar
Year: 97
Chassis: BadMuthaFuka
Rated Cap: All of us
can my bus be used as generator?
i have an electric box in engine compartment with run / stop switch and ports where wires could be ran in and out of. is this some sort of switch over to a generator setup?
Arvik is offline   Reply With Quote
Old 01-15-2016, 08:59 AM   #2
turf's Avatar
sounds like a remote engine start panel.
Turfmobile Build Thread
Old 01-15-2016, 09:10 AM   #3
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Our buses (RE200 and 3000) have a maintenance panel in the back that also overrides the front controls (when set). It's primarily a safety device so that someone doesn't jump into the driver's seat and takes off while people are working inside the engine bay.
Also makes for a great security device, because it disables the front controls
Captain Obvious on deviantArt
Old 01-15-2016, 07:58 PM   #4
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Not as it is, but if you added a high idle function and a 75 Kw generator head.....
now i know it wasn't the answer you were looking for but it is an answer
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
