Old 03-04-2013, 02:49 AM   #1
Can someone help me with some measurements?
Hi all,
So, I'm not really converting a bus, I'm working on an exhibit ON a bus, but I was wondering if folks could give me some advice and also could do me a favor (or knew off-hand). The bus I'm working on is the standard school bus size (13 windows long, 75" high interior). I won't actually get the bus on Tuesday (long story) and I need to purchase a ramp for the back emergency exit so that people can get on the bus in the front and then exit out the back.
My questions are:
1. What is the height of the back exit from the ground to the bottom of the door? I need to figure out the slope so I can purchase an appropriate ramp or stairs.
2. Does anyone use a ramp for the back exit? If so, what kind?
I would be SO grateful to get this info ASAP as it will give me a jump start on getting everything done instead of waiting...
Thanks!
Karen
houseofcakes is offline   Reply With Quote
Old 03-08-2013, 09:27 PM   #2
sportyrick's Avatar
Chassis: F33695
Re: Can someone help me with some measurements?
I have a 12' uhaul ramp that I ride my HD up and a set of stairs I made out if aluminum but I will have to get a length for you, sportyrick
Old 03-09-2013, 01:45 PM   #3
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
I will get you measurements from the ground to the back door for you. Not sure if my bus is the same as yours but we will see if this will help
Old 03-09-2013, 04:23 PM   #4
bapos's Avatar
Mine is ruffly 36" from the ground. Hope this helps
Measurements and isolation Letsbenomads Skoolie Conversion Projects 15 03-19-2014 10:10 PM
Measurements for a Chevy/GMC short bus. crazycal Short-Bus Conversion Projects 0 02-07-2014 01:14 PM
What are the basic interior measurements? Homeskooled Conversion General Discussions 4 09-24-2009 07:39 AM
