Old 05-17-2017, 10:42 AM   #11
When I drive it the voltage does not change, gosh I hope the alternator is ok.
I have a DT466E, she's old, 14k hours and 300,000 miles on it, but is still insanely strong. There is probably a lot of electrical issues since they cut out the box when they sold it to me and I have not yet fixed it, everything electrical works in the front but the back brake lights and stuff doesn't work. I'm still trying to fix the box.
Iheartbus is offline   Reply With Quote
Old 05-17-2017, 02:03 PM   #12
roach711's Avatar
Rated Cap: 19
From what I've read, the DT466 has no glow plugs so my best guess is that it;s time to test that alternator.
The Roach Motel
Old 05-17-2017, 02:24 PM   #13
Well, I would sit in it and then start it while watching the voltmeter guage or ammeter whichever you have, maybe both. Once it has fired up and running at a smooth idle, after the glow plugs are shutdown or maybe you have a grid heater, not sure, but they are high demand items on right after ignition. Sometimes for a few minutes, others not so much. Then if everything seems normal, turn on every switch you can find in the bus. That will put more load on the battery so the alternator should be outputting to keep up with that loss as well as the staring loss currents. Make note in your mind what you are seeing. Then, start turning those switches off after about 10 minutes, one by one and keep an eye out for changes in your instrument readings. You want an increase on the guages but they are not foolproof. If you are able to, then test for voltage reading at the batteries and from the alternator.
So how are the lights coming along or not?
Keep at it, you'll learn.
Old 05-17-2017, 04:53 PM   #14
I have a grid heater, it has a plug in to warm the block up located in the back of the bus. As far as I am aware, no matter how much I rev the engine, the voltage doesn't move at all.
Old 05-17-2017, 04:54 PM   #15
I bought a wire stripper and I'm stripping the wiring so I can reconnect the panel they tore out, hopefully once all the wires are reconnected (and hopefully, the right ones) I'll have a better understanding of what, if any, is missing.
Old 05-17-2017, 05:10 PM   #16
Chassis: Blue Bird
Engine: ISC 8.3
A grid heater is in the intake and is powered by the 12 volt system. Looking down into the intake, it looks like a stack of zig-zag plates not unlike the fins on a radiator. It pre-heats the air as it flows into the engine.
The mains plug you spoke of goes to a block heater. That heats the coolant and in turn warms the pistons and cylinder walls. It's different from glow plugs or grid heater which both work to heat air directly, but it works in concert with those for starting in cold weather. There can be a lot of different electrical-powered heaters on a diesel engine!
You could take the volt meter to the output stud on the back of the alternator and measure from there to the alternator case. If you don't have at least 13.2 volts there, and preferably higher like 13.5 to 13.9 volts or even a little more, then either there's a whole lot of load pulling the alternator down or else it just isn't producing like it should. While you're in the neighborhood, disconnect inspect and re-connect whatever connectors are on the alternator.
Just to clarify: do I understand correctly that the battery voltage is lower when the engine is running, even after it's warmed up, than when it's not running?
Old 05-17-2017, 05:15 PM   #17
Yes its lower. When the engine isn't running it is around 12.4v, while running the dash says it is at 11.
Ty for explaining the different heaters, I guess its a good thing that I have all these neat things on it for the winter days, cool!
We did take a voltage meter to the alternator and I can't remember what it was but it didn't seem to concern my friend who is an electrician, he didn't have time to fix the issue we were just trying to get home before the cops pulled us over for not having lights, and it was getting dark very quickly. I wish I knew what I was doing but I don't, otherwise i'd just take the wires I knew needed to work and put em together, this box they cut out (which really, really, really, really sux that they did this) is very complicated since the wires are not labeled, and even though they are color coded, there are multiple colors.
Old 05-17-2017, 05:25 PM   #18
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Just for giggles , disconnect the cable running to your starter solenoid, take a reading & let us know what you have, disconnected one side take a reading reconnect then disconnect the other side take a reading.
Old 05-17-2017, 07:06 PM   #19
I don't know where that is, but I'll ask the mechanic to do that if I go to one
Old 05-17-2017, 07:17 PM   #20
Chassis: Blue Bird
Engine: ISC 8.3
Are all these measurements taken with the same meter? We can't compare dash gauge readings with handheld meter readings mainly because dash gauges are notoriously inaccurate.
If you've started the bus several times and run it a while without spending any time with a battery charger, then the alternator must be working at least a little bit. The batteries would surely be dead by now if it weren't.
Do we have a handheld volt meter measurement at the batteries prior to start (yes, I think the 12.4 you quoted earlier was done this way) and after running for a few minutes (I'm not sure we have this one)?
