Old 06-01-2005, 02:22 PM   #11
Steve's Avatar
I like locking devices similar to that because they basically work automatically you don't need two hands to lock or unlock them.
Old 06-01-2005, 08:10 PM   #12
Year: 1981
Chassis: All American FE
Engine: Cummins 555 9.1 L diesel
door holders
Hi Andy,
Damn nice paint job.
My bus has little loops attached directly to the side of the bus--you hardly know they're there. Once you open the basement doors, though, you notice that the inside of the door has a similar loop, and a short stout rubber cord with two S-hooks, one of which is on the door loop, the other of which connects to the loop on the outside of the bus.
I'm not a fan of little plastic pieces myself, and my doors weigh a good piece, so I like the straps and hooks.
Branden
Lucinda
1981 Bluebird All American
Branden is offline   Reply With Quote
Old 06-02-2005, 03:54 AM   #13
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Hi Andy,
I also have little loops on the outside, but instead of rubber cords with S hooks, mine came with small chains. I like the setup (simple and reliable) and wouldn't change it for anything else.
Robert
Roasting8 is offline   Reply With Quote
Old 06-02-2005, 10:33 AM   #14
Door Hooks
Hi Robert , being a KISS fan (keep it simple stupid) I am not much into the plastic thing. Like Robert I have a "Crown" Bus. The method employed there is simple and very effective. On the inside of the door on one end is a small chain with an S hook attached. When the door is closed it just hangs down with a piece of rubber hose on the chain to prevent motion chafing. When the door is opened the S hook loops into a loop or eye attached to the body of the bus. My doors are 2' x 3' and no problems of any kind when door is being held open by the small chain and S hook. The eye attached to the body is only about 1/2" in diameter and painted body color is not even visible when door is closed. Crown used this method for many years and never changed so it worked for them.
J.B.
J.B. is offline   Reply With Quote
Old 06-02-2005, 11:36 AM   #15
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
You can also get those "T"-style holders that are on cargo trailer doors. They're pretty much a one-handed operation too (if installed correctly), and they're very inexpensive.
Griff is offline   Reply With Quote
Old 06-29-2005, 07:08 AM   #16
Vern1's Avatar
Greetings,
You can also use those "T" shaped door holders from any RV place.
The part that fits on the door has a slot and the hinged "T" part fits on the wall.
You open the door and drop the "T" in the slot and it holds it open.
They use them to hold the solid door open so you can use the screen door for ventilation.
Cheers,
Vern1
1976 International Wayne - ON THE ROAD!!
http://www.pettypb.com/bus
Vern1 is offline   Reply With Quote
Old 06-29-2005, 06:03 PM   #17
dammitAndy's Avatar
Engine: 370
Rated Cap: 44
Ya, I saw those on a semi trailer the other day. They looked pretty cool. I still havn't decided...
'89 Ford 370-2V Wayne - Sold :(
http://www.dammitandy.com/bus
Plotting the next project now. Looking for a clean diesel pusher with low rust/miles. Identical plans with plumming and biodiesel added :)
dammitAndy is offline   Reply With Quote
Old 05-18-2006, 03:51 AM   #18
I would love to have some boxes like that. I know I need something like that for the battery compartment. I have a voltmaster D904 deepcycle (398AH)@25A@80F. For tanks the only thing I could find cheaply was fruit 55 gallon plastic drums. I have no idea how to do this. I do have a friend that has a "wire welder" but not a cutter, so I'm going to try to cut the frame from the unused seats as the framework for the battery and water boxes.
Having a few extra under coach storage area would be a blessing as we have 7 normally in the coach.
My bus is a 1975 Ford B600 Sheller-Globe (Superior) Gas Conventional 9½ Windows.
Where do you get those doors?
cogyfarm is offline   Reply With Quote
120/240V household water heater installed and working bansil Electrical, Charging and Solar 46 12-13-2016 10:30 AM
Installed a Fireplace in my Thomas Pusher... usmcbay Conversion General Discussions 2 10-16-2012 03:14 PM
Has any body installed an auxiliary overdrive? grampsbutler Mechanical and Drivetrains 2 07-31-2011 11:50 AM
Building/buying basement or underside storage compartments? dentedvw Conversion General Discussions 1 02-06-2010 12:59 PM
Propane tank mount & waste tanks installed... GoneCamping Conversion General Discussions 0 11-05-2006 10:30 PM
