Old 06-17-2010, 01:56 PM   #1
NewSkewlHauler's Avatar
Engine: 8.2L Detroit N/A, Allison
Re: Carpet the ceiling?? Polyiso insulation??
I'm considering doing something similar on the ceiling. I was thinking about glueing a thin carpet pad to the metal (the guy at the carpet store said to use a spray adhesive), then put fabric (probably from Wally World) over the top of that. Basically, like an automotive headliner. My wife seems to think that Elmers glue-all should work...I'm skeptical. We'll see when I get to it if it works! Good luck with yours.
Ben.
NewSkewlHauler is offline   Reply With Quote
Old 06-17-2010, 03:40 PM   #2
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I don't think Elmer's will work. Try 3M elephant snot. That should work.
http://www.amazon.com/3M-Super-Mutip.../dp/B0000AZ735
I'm hungry!
You Gotta Let Me Fly
Old 06-17-2010, 08:14 PM   #3
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
I got a bunch of this. I'll let y'all know how it works.
M1031 is offline   Reply With Quote
Old 06-18-2010, 01:08 AM   #4
Moderator
crazycal's Avatar
I can tell you that it works pretty good. I have bought many dozens of cans over the years. Just don't buy more than you need because it doesn't store well. I had full unused cans go bad.
I'm hungry!
Old 06-18-2010, 01:10 AM   #5
Moderator
crazycal's Avatar
Originally Posted by Smitty
Remove the inner ceiling panels, and insulate, that way you lose no head-room. Cover with luan, then carpet if that's what you want to do......that way you only loose about 1/2" of head-room, and can get 1+ plus of rigid insulation in the roof.
Smitty
I hope he doesn't have as many ribbits as the Blue Bird because it will take him about two years to cut those ribbits off. There must be 1 1/2 million ribbits on the inner roof.
I'm hungry!
Old 06-18-2010, 02:40 PM   #6
houskou's Avatar
Coachwork: flatnosed
Chassis: amtran/bluebird/thomas
Engine: diesel
will removal of inner roof panels result in some loss of structural integrity? If so any idea how much?
The sun is the same, in a relative way, but you're older; shorter of breath, and one day closer to death.
Pink Floyd - Dark Side of the Moon
houskou is offline   Reply With Quote
Old 06-18-2010, 03:23 PM   #7
Stuff's Avatar
shuttle bus' have carpet all over them. all the carpet is glued to pannels that are mounted in place. should be nice in a full sized bus. go with commercial grade me thinks.
Old 07-10-2010, 01:22 PM   #8
browncrown's Avatar
Rated Cap: 79 at Birth
I glued foam insulation to the metal and then the carpet onto that using Liquid Nails...it worked really great and have not had any loose carpet or foam in over a year now.
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 07-10-2010, 01:55 PM   #9
Elliot Naess's Avatar
Engine: 5,9 Cummins
Strictly for amusement; to illustrate what an interesting world we live in: I have a can of that 3M 77 glue that I use occationally for this and that -- maybe once every couple of years. Works great every time. I bought that can for the upholstery in my second roadster -- around 1990.
Old 07-10-2010, 06:20 PM   #10
lornaschinske's Avatar
Rated Cap: 89
I just want to watch you guys vacuum the carpet! It should be a kick to watch! Hope you don't have pets... dusting the carpet on the ceiling for fleas would be a hoot!
Fulltime since 2006
Old 10-13-2010, 06:26 PM   #11
In case of flees, Just lysol the carpet. The flees dont like the stuff.
Wall and ceiling insulation? Kent Dorfman Conversion General Discussions 39 12-26-2020 06:15 PM
Insulation Board: Polyiso or Foam? Westward Conversion General Discussions 5 09-27-2013 11:27 AM
Carpet on ceiling Soundman1 Conversion General Discussions 12 08-04-2012 02:28 PM
Ceiling Insulation Wayward2 Conversion General Discussions 1 03-30-2010 08:41 PM
Ceiling Insulation Seeria Conversion General Discussions 0 12-30-2009 08:26 AM
