Old 12-30-2009, 09:26 AM   #1
Seeria's Avatar
Ceiling Insulation
Correct me if I missed it but I didn't find a thread specific to this topic.
I'm looking for ideas on beefing up the topside insulation, inside and out. What I am considering at the moment is listed below so please toss me pros, cons, and suggestions. Bus will be south in winters, PNW in summers.
On the outside topside I want to do therma-cell reflective painting. Whether this cermaic-ball paint stuff has any true insulation value seems debatable by some, but I figure it isn't that expensive to add to a pot of paint.
Inside I was thinking of doing a coat of rustoleum then adding overlapping coverage of radiant barrier sheeting which will be covered by cork flooring tiles for added R and sound insulation qualities.
Inside the inside I have no idea. How hard is it to get into that area? Costly? I would rather not be replacing walls/ceilings/etc with plywood or laun stuff. Metal is much preferred.
Is there any plus to inserting radiant barrier btwn the inside/outside metal ceiling as to simply lining the inside with it?
Can fiberglass sheets of insulation be removed in there and easily slid back in perhaps?
Maybe spray foam insulation?
Are there other types of insulation I'm missing here?
Wall and ceiling insulation? Kent Dorfman Conversion General Discussions 31 10-01-2018 06:08 PM
Inserting Expanding Foam in the Ceiling for Insulation greatidea Conversion General Discussions 5 10-19-2010 06:18 PM
Carpet the ceiling?? Polyiso insulation?? NewSkewlHauler Conversion General Discussions 10 10-13-2010 07:26 PM
Ceiling Insulation Wayward2 Conversion General Discussions 1 03-30-2010 09:41 PM
Ceiling Height oldog12 Conversion General Discussions 3 01-01-2010 12:07 AM
