Old 03-07-2018, 12:34 PM   #1
Chassis: 3000
Engine: 7.6 L / DT466
Rated Cap: 72 Pass.
Ceiling material?
Hey everyone!
Iím curious what you guys use. Either tongue and grove 5/16Ē pine boards or the thin cheap bead board for your ceiling?
Thanks!!
TheRoanBus is offline   Reply With Quote
Old 03-07-2018, 01:06 PM   #2
Originally Posted by TheRoanBus View Post
Hey everyone!
I’m curious what you guys use. Either tongue and grove 5/16” pine boards or the thin cheap bead board for your ceiling?
Thanks!!
I'm down in Brunswick - and am concerned about preventing mold/mildew since our area gets extreme heat/humidity levels. I am pretty certain I'm going with FRP panels of some flavor both in ceilings and walls.
TrailLifeBill is offline   Reply With Quote
Old 03-07-2018, 01:23 PM   #3
My plan is a path down the center of the roof with luan about 2.5' wide and then t&g from there down to the floor. I hadn't seen 5/16" t&g, sounds easier to wrk with, though it doesn't need to bend.
Old 03-09-2018, 04:08 PM   #4
1/4" or 5/16", not sure exactly how thick, but that is what Home Depot is selling these days. I was planning on going with the T&G for the ceiling, and cabinet doors / drawer fronts, and 1/4" cabinet grade ply for the walls...
dbhost is offline   Reply With Quote
Old 03-12-2018, 08:00 PM   #5
Chassis: MVP
Engine: CAT 3116
I used 1/4" t&g pine screwed directly to the ceiling ribs. I'm 6'4" and ceiling height is important, so there was no room (short of a roof raise) for anything thicker! I got it a Lowes, the planks are 8' long and about 4" wide, and they are made by a company called Empire. The pine that I used was on closeout and discontinued, so I bought every piece they had. I think you can still get get it in cedar, but it is more $.
Piersg is offline   Reply With Quote
Old 03-12-2018, 09:11 PM   #6
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
3/4 x 5 1/2 t&g 16 g finish nailed
File Type: jpg user4681_pic14838_1483448660bus ceiling.jpg (35.2 KB, 33 views)
my build pics
Old 03-12-2018, 09:54 PM   #7
Can you post a pic showing the screw attachment? I want to attach directly to the ribs also, but don't want a million pieces of hardware showing.
Old 03-12-2018, 11:07 PM   #8
Chassis: MVP
Engine: CAT 3116
This is a close up of the ceiling looking straight up. The screws are all countersunk, and unless you are looking straight up, they are not noticeable:
You can see the screws in the foreground in this shot, but they are not noticeable beyond that:
Old 03-12-2018, 11:36 PM   #9
I was going to ask if you used self tappers, but see you predrilled and countersunk, correct.
Old 03-12-2018, 11:56 PM   #10
plfking's Avatar
Rated Cap: 34
Nicely done.
It looks like you screwed directly into the ribs.......do you ever have any condensation on the screw heads?
Don
The Busted Flush
Old 03-13-2018, 09:44 PM   #11
Chassis: MVP
Engine: CAT 3116
Yes, I drilled, countersunk, and used self tappers.
Old 03-13-2018, 09:46 PM   #12
Chassis: MVP
Engine: CAT 3116
Originally Posted by plfking View Post
Nicely done.
Not so far.I live in S Florida, so the swings in temperature aren't really bad. It just goes from hot and humid to hotter and humid!
bead board, ceiling, pine, tongue and grove
