Old 10-18-2018, 11:09 AM   #1
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Ceiling sheet metal gauge
I will be skinning the original door so its a solid door but is still a school bus door. I wondering if i can recycle the sheetmetal from the ceiling?
mikeypj is offline   Reply With Quote
Old 10-18-2018, 01:23 PM   #2
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
How will you see out? Ive thought of that but you need visibility there.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 10-18-2018, 03:12 PM   #3
I agree...you definitely need some vision in that spot so some kind of window is called for. I even added a small "curb view" window down real low. Helps a lot when ooching up next to gas pumps and such.
Old 10-18-2018, 04:52 PM   #4
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
I will be cutting 4 windows in the sheet metal to match windows in the door.
Old 10-18-2018, 04:53 PM   #5
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Did you create this door or just skin it?
Old 10-18-2018, 10:13 PM   #6
Made from scratch. And a nightmare! The leading edge is straight but the back edge has a tiny amount of curve.
Old 10-19-2018, 10:35 AM   #7
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Nice, good fit too.
Old 10-19-2018, 09:04 PM   #8
Now...a warning.
If you build a proper door frame, then skin it , it should fit. And mine did. Prewfectly. But...if...after the skin is on (14 ga. in my case) you come back and cut out a big area (like that large window)...it just may crank itself out of shape due to relieving some stress across the skin.
This one did.
Maybe 3/8's of an inch now out of alignment (along the "straight" edge). Still need to correct it and still uncertain as to exactly how to go about it. A buddy at the sheetmetal shop that did the skinning thinks he can torque it back where it should be but we don't know yet. That sucker took a couple of months (and a fair amount of $$$) to build so I am reeeaaally hoping we can correct it.
Wish me luck.
Old 10-20-2018, 10:21 AM   #9
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Now...a warning.
This one did.
Wish me luck.
Good luck! Im not creating a new door. Im joining the 2 halves together. (I guess that could be called a new door). Luckily i have a friend who is a sheet metal worker(tinner). I may just run a 8" piece down the middle front and back. Glue and bolt it on and be good to go.. im guessing the ceiling metal is 14-16 gauge, so im going to use it. In a perfect world skinning it is the correct way to do this, but it isnt a perfect world..lol
Old 10-20-2018, 10:22 AM   #10
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Now...a warning.
This one did.
Wish me luck.
Does your door have body contours your trying to match?
